Results 1 to 12 of 14
Plumbing & Plumbers Forum - What is this sytem called?
Discuss What is this sytem called? in the Central Heating Forum at Plumbers Forums; I have come across a system that heats the hot water off the radiator circuit, with no valves, cylinder stat or wiring centre. What is this sytem called, why was ...-
22-08-2012 #1New to Plumbing Forum
- Dec 2011
- 7
- 5
I have come across a system that heats the hot water off the radiator circuit, with no valves, cylinder stat or wiring centre. What is this sytem called, why was it done this way? Is this an old historic CH design before the Y, C, S plans etc came along or something?
There is no way to heat the water without having the rads on, unless you use the immersion. there is a two channel programmer, but it does seem to give much choice other than off or on!
any ideas?
22-08-2012 #2Plumbers Arms member
- Jun 2012
- London/Kent
- 1,771
- 104
- Thanked 190 Times in 186 Posts
Re: What is this sytem called?
Called gravity HW with pumped heating, pump for heating controlled via programmer & room stat. Boiler on for HW so domestic hot water temp same as boiler stat setting.
The Following User Says Thank You to chris watkins For This Useful Post:
pyesmith (23-08-2012)
22-08-2012 #3UK Plumbersforums Trusted Advisor.
- Dec 2011
- 2,995
- 3
- Thanked 209 Times in 200 Posts
Is this a joke?
Sent from my iPad using Tapatalk HD
22-08-2012 #4Plumbers Arms member
- Jun 2012
- London/Kent
- 1,771
- 104
Why was it done that way ? well pumps didn't like the high flow temps so were fitted on the return were it was cooler, no domestic zone valve to speak of, the main reason - install & gas were cheap (Northsea gas was just about to come on stream, so tamz told me anyway)
22-08-2012 #5UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,546
- 281
- Thanked 1,206 Times in 1,073 Posts
Sounds like it is fully pumped and is an old system from the 70's pioneered by the likes of servowarm and FEP, 2 big heating players in the 70's and early 80's. Just a cheap to install early system of which there are still many around.
FEP's were usually Baxi WM's with the pump inside the casing, the return to the cylinder is 8mm and all the fittings are compressions.
If you are lucky you may find one of these that were fitted by Servowarm
An early UNmotorised valve
If you want the heating off shut the rad valves.
And big money and a ticket to the dry out clinic to be had building the Sullom Voe terminal to bring it in! (I wasn't allowed to go)
The Following User Says Thank You to tamz For This Useful Post:
22-08-2012 #6Plumbers Arms member
- Jun 2012
- London/Kent
- 1,771
- 104
23-08-2012 #7UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,546
- 281
We had one of these in my mums house in the early 70's. The only people in the street with gas heating and a colour telly
Quite a fascinating beast of a boiler.
I took a Suprime model (the one with the wooden surround) out about a year or so ago from a house in Edinburgh. Still in pristine condition complete with mostly truwel pipe (also surprisingly pristeen but i ripped it out anyway) the rads with the dimples on the back and an urn in the bedroom. That is where the summer winter valve in the pic came from. It had the lable on it when i took it out
The only reason the old dear changed it was because the guy who fixed it (a local man to me) had retired at 75. He had worked with Servowarm in the 70's and when they more or less closed down operations up here in the 80's he set up a business repairing and servicing servowarm boilers. Now that was a nice wee niche market.
23-08-2012 #8Plumbers Arms member
- Jun 2012
- London/Kent
- 1,771
- 104
I think their HQ was down here fairly close to me, in Bromley?, until they went pop. Use to see a good few anyway, did not know they had got as far up to give you there unique pleasure.
Anyways I am off to bed now got a busy day tomorrow, (NOT). Unlike "I only need 40
's" now I am a little older. I find an late afternoon power nap does me find, mind you I have always been like that, just use to take it with a friend
23-08-2012 #9UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,546
- 281
They were quite a big concern up here in the 70's. Had a lot of guys working for them. They even did new builds at the time.
23-08-2012 #10New to Plumbing Forum
- Dec 2011
- 7
- 5
23-08-2012 #11UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 6,041
- 125
- Thanked 593 Times in 565 Posts
btw im commercial, NOT.
23-08-2012 #12Plumbers Arms member
- Jun 2012
- London/Kent
- 1,771
- 104
Fitting TRVs to an old sytem Help please !
By Joely in forum Central Heating ForumReplies: 10Last Post: 13-06-2012, 01:22 PM -
Sytem recently power flushed,now new pump sucking in air-please help
By PSH in forum Central Heating ForumReplies: 25Last Post: 01-12-2011, 10:16 AM -
What Certificates should I have whe buying 'newbuild' house with Underfloor C/H sytem
By nimrod in forum Central Heating ForumReplies: 1Last Post: 14-11-2011, 11:44 PM -
WISY rainwater sytem
By bigbeno in forum Plumbing ForumReplies: 1Last Post: 06-04-2010, 09:23 PM -
Problem with heating sytem - help please
By chrysagon in forum Central Heating ForumReplies: 6Last Post: 15-11-2009, 04:30 PM
4Likes
Heating on upstairs when it is ...
5 Minutes Ago in Oil and Solid Fuel Forum
