Page 1 of 4 1234 LastLast
Results 1 to 15 of 58
Plumbing & Plumbers Forum - flue confusion!!!
Like Tree15Likes
flue confusion!!!
Discuss flue confusion!!! in the Central Heating Forum at Plumbers Forums; can someone explain when a flue is not part of a central heating system? Thanks Jackie...
    Aug 2012
    17
    Default flue confusion!!!
    Thanks Jackie
    mountainman's Avatar
    Jan 2012
    Essex
    3,198
    Default
    More information is required Jackie, can you be specific as to why you are asking this question?
  3. Proud to be 'Part P', the world is now my mollusc!
  4. The Following User Says Thank You to mountainman For This Useful Post:
    jackie mcc (19-08-2012)
  5. #3
    7,217
    Default Re: flue confusion!!!
    When it's electric?
  6. The Following User Says Thank You to SimonG For This Useful Post:
  7. #4
    Aug 2012
    17
    I think i am going mad a contractor turned my boiler off last week due to the flue been worn. An engineer called out today and said that the flue is not part of my boiler so therefore i am not covered with my breakdown cover. I have asked some mates that know a little about central heating systems, they have all said that the engineer is wrong. The make of the boiler is a Ferroli 701 it is 13yrs old positioned on an outside wall in my kitchen with the flue coming out the top and through the wall, does this make the flu part of the boiler?
  8. #5
    7,217
    It sounds like somebody trying to get out of not doing what they're supposed to. Better check the small print, I have seen oil boiler policies that cover nothing outside the boiler casing so would exclude flue.
    Stuthewarrior likes this.
  9. The Following User Says Thank You to SimonG For This Useful Post:
  10. #6
    BOD
    BOD is offline
    BOD's Avatar
    Nov 2009
    10,513
    Did they come round at ten to five on a friday night ? What company is refusing to replace it ?
  11. The Following User Says Thank You to BOD For This Useful Post:
  12. #7
    Aug 2012
    17
    thanks,
    I have checked it over and over again and it clearly says that "flues that are not part of the boiler or appliances are not covered". from what i have said do you feel that the flue is a standard flue that is fitted to the boiler
  13. #8
    BOD
    BOD is offline
    BOD's Avatar
    Nov 2009
    10,513
    Sadly Jackie to replace the flue you will need a gas safe engineer but from what you've already said I'd suggest an independent person , try putting a post on here in the I need a plumber section
  14. The Following User Says Thank You to BOD For This Useful Post:
  15. #9
    tamz's Avatar
    Scotland
    9,348
    Of course a flue is part of the boiler. It can't function without it. It is not however an integral part.
    Follow Simon's advice and check the small print of the policy. Even if it does cover the flue you may not be able to get a replacement any more so it may be new boiler time i'm afraid.
  16. The Following User Says Thank You to tamz For This Useful Post:
  17. #10
    JAP&H's Avatar
    May 2012
    North Lincolnshire
    253
    Quote Originally Posted by jackie mcc View Post
    Hi Jackie, what's worn on the flue? Has the contractor left paperwork explaining his actions?
    As has already been mentioned check your breakdown agreement. Some policies cover boiler only, some cover boiler including flue and some even cover controls.
    Haven't heard of a flue being worn before, is this down to corrosion, weather damage, poor installation?
    It doesn't matter what the temperature of a room is, it's always room temperature.
  18. The Following User Says Thank You to JAP&H For This Useful Post:
  19. #11
    Aug 2012
    17
    EON they came today, but the service contractor came on a wed at 430pm
  20. #12
    Jan 2012
    Essex
    3,198
    Default
    So what are eon telling you needs to be done?
  21. The Following User Says Thank You to mountainman For This Useful Post:
  22. #13
    Aug 2012
    17
    flue pipe rotten needs replacing also seal which they will replace as i am covered, but they are refusing to pay for the replacement "flue as he has said that it is not part of the boiler of appliances" i asked the engineer what that meant he said that if the flue was behind a wall or somewhere that it would be hard to reach, the flue in question is above the boiler and through the outside wall
  23. #14
    661
    Flue not part of the boiler or appliance would be flue liner or external prefabricated stack used with an open flued appliance.
    Ask EoN if they are prepared to disconnect your faulty flue so you can use the boiler without it, as according to them "It's not part of the appliance"
    EON know a replacemnt flue is most likely not available and that they'd have to fit a new boiler so are trying to get you to pay for it.
  24. The Following User Says Thank You to snowhead For This Useful Post:
  25. #15
    Jan 2012
    Essex
    3,198
    Default
    Quote Originally Posted by snowhead View Post
    I agree.
    I suppose it all comes down to the economy syndrome.
    The customer thinks that they are getting a 'good deal' boiler service and cover for £16 a month but things are rarely that good in reality.
    Nostrum, rodders and chris watkins like this.
  1. Bath Confusion
    By direct-network in forum Plumbing Forum
    Last Post: 29-07-2012, 11:28 PM
  2. confusion C&G and NVQ?
    By a.h in forum Plumbing Courses
    Last Post: 14-03-2011, 02:39 PM
  3. Gas rate confusion
    By TECHY 44 in forum Central Heating Forum
    Last Post: 17-12-2010, 08:24 PM
  4. Aqualisa confusion
    By MarkyMark in forum Bathrooms, Showers and Wetrooms
    Last Post: 16-09-2009, 05:04 PM
