Results 1 to 9 of 9
Plumbing & Plumbers Forum - blocked 10mm plastic pipes to rads
  • 1 Post By tamz
Discuss blocked 10mm plastic pipes to rads in the Central Heating Forum at Plumbers Forums; tried mains pressure water,a foot pump,blocked any idea's cause it got me....
    May 2009
    nb b
    1,603
    Default blocked 10mm plastic pipes to rads
    kay-jay's Avatar
    May 2008
    Bolton
    4,189
    Default
    Have you tried reversing the direction?
  3. IN CERVESA FELICITAS - IN BEER THERE IS JOY
    tamz's Avatar
    Scotland
    9,384
    Default Re: blocked 10mm plastic pipes to rads
    You could try putting put a compressor on it but even that is not guaranteed. Usually quicker and easier re pipeing it if you can.
    JCplumb likes this.
    Jun 2010
    698
    If it's old 10mm pipe it could be single barrier & it'll block up again, replace it if you can.
    May 2009
    nb b
    1,603
    Quote Originally Posted by kay-jay View Post
    yes about 20 times..
    May 2009
    nb b
    1,603
    Quote Originally Posted by tamz View Post
    your right,but the length of the runs are terrible,not going to be easy,skirts of, behind walls etc.
    Steady Plumbing Forum Contributor mike-c's Avatar
    Apr 2012
    Edinburgh
    204
    Is there a chance that the pipes are kinked behind the rads where they exit the wall?
    sometimes when the pipes come up the way behind the rads and are then brought through the wall and then routed back down to the valves they can become kinked especially when a bit of heat reaches them and they become soft.
    May 2009
    nb b
    1,603
    Quote Originally Posted by mike-c View Post
    i use a stiff c able to rod pipe work i'm hitting resistance about 4 mtrs in could be kink,a fitting,a blockage..?it will not budge what ever it is
    Top Plumbing Forum Contributor Paulus's Avatar
    Oct 2010
    Cheshire
    662
    Sounds like surgery is required, cut out the badness and replace.
    If we find we cannot help others, the least we can do is to desist from harming them. Dalai Lama.
  1. Blocked pipes and valves, what is this stuff tho...?
    By gassafe in forum Plumbing Forum
    Last Post: 15-09-2011, 04:17 PM
  2. 10mm plastic pipe freezing
    By Foston in forum Central Heating Forum
    Last Post: 07-09-2011, 10:42 AM
  3. 10mm reducer on rad valve to plastic pipe
    By gates1979 in forum Plumbing Forum
    Last Post: 07-12-2010, 11:17 PM
  4. slow heating rads on 10mm
    By perfect plumb in forum Central Heating Forum
    Last Post: 14-11-2010, 05:05 PM
  5. joining 10mm copper pipes
    By apcdave in forum Central Heating Forum
    Last Post: 21-04-2010, 09:39 PM
blocked central heating pipes
10mm plastic central heating pipe
blocked heating pipes
central heating pipes blocked
10mm plastic heating pipeblocked 10mm copper heating pipeshow to clear blocked 10mm central heating pipe
