Plumbing & Plumbers Forum - Leaking Mixing/Blending Valve
  • 1 Post By Simon F
Discuss Leaking Mixing/Blending Valve in the Central Heating Forum at Plumbers Forums; Hi, My hot water tank has developed a leak so I called a plumber out to have a look. He said that the leak was coming from the 'blending valve', ...
    Aug 2012
    Default Leaking Mixing/Blending Valve
    My hot water tank has developed a leak so I called a plumber out to have a look. He said that the leak was coming from the 'blending valve', I was hoping that he would suggest tightening something or replacing a part, but he suggested I get his colleague out to quote for an entire new heating system. His reasons being that the tank looks corroded and may not survive the fitting of a new valve (if he can find one that is?).
    The current system may be about 20 years old, but it works perfectly well and I've not had any previous issues with it. It just seems a little drastic to replace everything (at a price of £1800) to fix a leak.
    Any advice will be appreciated. Many thanks.
    Simon F's Avatar
    Nottingham
    1,416
    Default Re: Leaking Mixing/Blending Valve
    Hello Madge and welcome along,
    working on an old cylinder may well be enough to disturb a weak point and it start leaking.
    that would not mean the need for a complete new heating system,boiler and all??
    but without seeing it, not so easy to judge.
    best advise is get some other quotes, see what they say/recommend.
  3. SimonG likes this.
    May 2010
    1,914
    Hello Madge84 and welcome where is you location maybe someone on the forum would be available to come and give you a second opinion regards turnpin
  1. Satchwell 201011 mixing valve
    By thereisawizza in forum Plumbing Forum
    Last Post: 12-07-2011, 01:51 PM
  2. 3 or 4 port mixing valve
    By ExpatinFrance in forum Plumbing Forum
    Last Post: 08-06-2011, 05:58 PM
  3. Thermostatic mixing valve
    By gates1979 in forum Plumbing Forum
    Last Post: 18-01-2011, 05:57 PM
  4. Thermostatic mixing valve?
    By Triffid grower in forum Central Heating Forum
    Last Post: 11-09-2010, 07:42 PM
  5. Hot Water Cylinder Mixing Valve
    By TheArtfulDodger in forum Plumbing Forum
    Last Post: 06-02-2010, 07:08 PM
central heating mixing valves
boiler blender valve dripping
professional blending valves
hot water blending valve leaking
boiler mixing valve leaking
central heating blending valve
leaking heating blending valve
