Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Plumbing & Plumbers Forum - gas card meter
Like Tree20Likes
gas card meter
Discuss gas card meter in the Central Heating Forum at Plumbers Forums; A tenant has just run out of gas and so has topped up. The boiler is now not working and it says "flame failure" I am thinking there is not ...
    Banned
    Sep 2010
    338
    Default gas card meter
    I am thinking there is not enough gas being pulled through. I have had her running the hot water, but still no joy. She is going to top up a bit more as she has only added £6 and has £1.80 on the meter now.
    Any other things i have over looked. I dont want to call out the engineer yet because i think it is this simple problem
    BOD
    BOD is offline
    BOD's Avatar
    Nov 2009
    10,513
    Default Re: gas card meter
    If there's gas there's gas , what boiler is it ? Maybe needs purging through the hob ?
    Banned
    Sep 2010
    338
    it is a main combi. there is no gas hob, only gas fire. could we purge the gas here?
    why does the gas need purging ?
    741
    Default
    Has the boiler been reset??
    BOD
    BOD is offline
    BOD's Avatar
    Nov 2009
    10,513
    I'd get the fire going then go back to boiler
    Banned
    Sep 2010
    338
    dont think she can light the fire either. I am thinking she hasnt put enough on the card token
    BOD
    BOD is offline
    BOD's Avatar
    Nov 2009
    10,513
    What's the meter reading , if it's saying credit she has gas , if there's no gas meter is caput
    mountainman's Avatar
    Jan 2012
    Essex
    3,198
    Default
    Unless the meter says OFF then it will need resetting.
    751
    Has the anti tamper mechanism triggered on the meter,if so it will need resetting
    APPlumbing likes this.
    Banned
    Sep 2010
    338
    where is this anti tamper setting ? How will i know it has been set off.
    Jan 2012
    Essex
    3,198
    Default
    Look at the display and if it says OFF then the ATD has been activated and you'll have to get the supplier out to reset it.
    Newcastle Upon Tyne
    238
    I think If she has tried to use the appliance after she has ran out of gas then the pipes will be full of air and need purged! I take it you're not gsr, just keep running and trying to re set the boiler and it will purge itself?
  13. #13
    Jan 2012
    Essex
    3,198
    Default
    Quote Originally Posted by jefaz View Post
    Exactly where did the air come from if she ran out of gas?
    heliotrope, croppie and linksman like this.
  14. #14
    tamz's Avatar
    Scotland
    9,348
    And how would they fill with air?
    croppie and gas man like this.
  15. #15
    Newcastle Upon Tyne
    238
    So if you had a boiler with a pre paid meter and the gas ran out as you were using the boiler the boiler would shut down as it has used all it's gas! What would be left in the pipe? It isn't a vacuum is it? So there must be something in there
  1. taking mobile credit card/debit card payments.....
    By moogwai in forum Plumbing Forum
    Last Post: 07-05-2012, 07:50 PM
  2. gas meter supply under floor constitutes moving meter?
    By southcoastboile in forum Central Heating Forum
    Last Post: 06-05-2012, 08:31 AM
  3. Pay by card meter, how to switch on ???
    By greg94 in forum Gas Safe Register Forum - Public Forum
    Last Post: 18-09-2011, 02:34 PM
  4. Gas card meter gas rate?
    By cjuk in forum Gas Safe Register Forum - Public Forum
    Last Post: 23-08-2011, 08:54 PM
  5. Commercial unit, huge meter and normal G4 meter?
    By theanalyst in forum Gas Safe Register Forum - Public Forum
    Last Post: 17-08-2010, 06:18 PM
card meter 376
gas card meter forum
