Page 1 of 5 1234 ... LastLast
Results 1 to 15 of 70
Plumbing & Plumbers Forum - Why size of gas pipe?
Like Tree38Likes
Discuss Why size of gas pipe? in the Central Heating Forum at Plumbers Forums; My boiler needs 22mm pipe from the meter, this I understand. So why is the gas connection on the boiler only 15mm, needing an adapter from 22mm to 15mm close ...
    stratobuddy
    Default Why size of gas pipe?
    So why is the gas connection on the boiler only 15mm, needing an adapter from 22mm to 15mm close to the boiler.
    Why isn't the boiler connection 22mm?
    Simon F's Avatar
    Nottingham
    1,424
    Default Re: Why size of gas pipe?
    if the manufacturer has made the gas connection 15mm then that's sufficient for connection to the boiler.
    its all to do with resistance from the pipe walls affecting the flow of gas, which is very low pressure (19-23mbar )
    the longer the run of pipe the bigger pipe size needed to compensate.
    so the fact that the connection at the boiler is 15mm does not mean that 15mm would be acceptable for the complete run.
    gas is not water which would be fine in 15mm due to a pressure probably 100-200 times higher!
  3. Last edited by Simon F; 09-08-2012 at 04:41 PM.
  4. The Following User Says Thank You to Simon F For This Useful Post:
  5. #3
    stratobuddy
    Thanks for the above, but wouldn't it be easier for the installer if the boiler connection was also 22mm so the pipe could be connected straight in?
  6. #4
    Simon F's Avatar
    Nottingham
    1,424
    some boilers particularly combi's do have a 22mm connection for the gas,
    its no great challenge to fit a reducer on the last stretch of pipe
    depending on the length of pipe and what its supplying could need to come from the meter in 28mm even 35mm and then be teed of to whatever appliances or reduced down as needed
  7. The Following User Says Thank You to Simon F For This Useful Post:
  8. #5
    tamz's Avatar
    Scotland
    9,363
    Quote Originally Posted by stratobuddy View Post
    Why does your gas hob come with a 15mm connection when the size of the burner jet is smaller than a pin hole?
    Simon F likes this.
  9. #6
    Koogatubac's Avatar
    Jan 2011
    1,210
    Default
    Haha Newer boilers require bigger size gas pipe,
    Older boilers werent as big in demand for gas, therefore alot have been on 15mm.
    Nowadays its good practice to come off the gas meter in 28mm (all depends how far the boiler is and how many appliances is going to be run off it.)
    Just as those guys above have mentioned
  10. #7
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,101
    Quote Originally Posted by tamz View Post
    why does a duck spend most of its time with its head and mouth under water when there is a smaller hole in the rear, can they mimic a wave runner?........!...............
    ¿ʞɹoʍ sɐƃ
  11. #8
    AWheating's Avatar
    WestMidlands
    5,803
    the appliances connection has no bearing on the size of the pipework required to supply the gas to it. The gas pipe is sized on a number of factors like route and length of pipe run, appliance size/rate, type of material use ect.....
    btw im commercial,
    NOT.
  12. #9
    kirkgas's Avatar
    Dec 2009
    Coatbridge, Lanarkshire
    3,515
    who says the boiler needs 22mm for every install? if it has a 115mm connection there will be situations where 15mm is adequate, in different houses with different layouts 22/28/35 might be needed, as others have said some have a 22mm connection so they need
  13. #10
    Dec 2009
    865
    The real answer to your question is available after serving a five year apprenticeship, working on gas for a few years then proving competence by completing never ending expensive courses in Gas Safe procedures, you don't really expect a detailed answer free of charge?
    Or do you?
    Anton likes this.
  14. #11
    Howsie's Avatar
    2,687
    Default
    Why don't you ask the manufacture the question? Only they know the answer as they designed the thing.
    EX VI TERMINI
  15. #12
    Koogatubac's Avatar
    Jan 2011
    1,210
    Default
    Lol howsie, i like you 'DESIGNED THE THING' HAHA
  16. #13
    stratobuddy
    All 4 plumbers that gave me an estimate said the existing 15mm supply would not be big enough and they would have to run a 22mm pipe.
  17. #14
    croppie's Avatar
    Portadown, United Kingdom
    7,661
    There are far too many reasons which we know and you won't. Satisfy yourself with this answer.
    Because it does.
    Croppie
    (By the way, I'm commercial!)
  18. #15
    1,366
    What are the chances of all 4 qualified gas engineers being wrong?
  1. gas hob pipe size
    By gregg1908 in forum Plumbing Forum
    Last Post: 21-06-2011, 05:34 PM
  2. Replies: 1
    Last Post: 22-05-2011, 05:27 PM
  3. Pipe size
    By dylan in forum Central Heating Forum
    Last Post: 13-01-2011, 11:15 PM
  4. gas pipe size
    By stewarty in forum Central Heating Forum
    Last Post: 14-06-2010, 09:54 AM
  5. Pipe size?
    By plumbingdazman in forum Plumbing Forum
    Last Post: 27-05-2010, 05:20 PM
15mm gas pipe combi boiler
hob gas pipe size 8mm
results of incorrectly sized gas pipe
can i put a 15mm to 22mm adaptor on boiler
central heating incorrect size of gas piping from meter
15mm or 22 mm pipe for 8 burner cooker
boiler pipe adapter size
