Plumbing & Plumbers Forum - powerflushing hot water heat exchangers
Discuss powerflushing hot water heat exchangers in the Central Heating Forum at Plumbers Forums; hi everyone just wondering if you guys have had any luck with powerflushing hot water heat exchangers ? we have the kamco pf with magnet,heater element and pump head adaptor. ...-
06-08-2012 #1Plumbers Arms member
- Jul 2012
- norfolk
- 318
- 14
- Thanked 15 Times in 15 Posts
hi everyone just wondering if you guys have had any luck with powerflushing hot water heat exchangers ? we have the kamco pf with magnet,heater element and pump head adaptor. normally get called to jobs when its just to late to try cleaning them { barely any flow } so replacement required. like to use the pump head adaptor as i can get to the hw heat exchanger, but dont know weather its worth us buying the secondary adaptor blocks. a bit unsure as to how it can suit all of the different connections/centres ? replacements seems to be the best way and no call backs !!
06-08-2012 #2UK Plumbersforums Trusted Advisor.
- Apr 2011
- Newcastle Upon tyne
- 6,115
- 306
Re: powerflushing hot water heat exchangers
Personally neily01 what would it save? p-hex is about £100 ... chemicals and labour to faff on, about the same if not more less guaranteed success by just swapping! Unless they're on some kind of contract and your paying peanuts in labour I'd just swap it! Obviously if the p-hex is double expensive then consider cleaning! IMHO
When I was at B-Gas we use to clean them on a machine but at that time I was paid £15/hr
The Following User Says Thank You to diamondgas For This Useful Post:
neily01 (06-08-2012)
06-08-2012 #3Plumbers Arms member
- Dec 2011
- Somerset
- 1,824
- 94
- Thanked 185 Times in 180 Posts
Agreed not worth it, especially if you end up having to replace it anyway then works out doubly costly.
Read more: http://www.ukplumbersforums.co.uk/pl...#ixzz2AdEwjWbf
The Following User Says Thank You to Roger Welton For This Useful Post:
06-08-2012 #4Plumbers Arms member
- Jul 2012
- norfolk
- 318
- 14
kinda what i was thinking. have cleaned them under the tap before when on a job and happen to notice early signs say on a service when trying to running boiler flat out. quite satisfying but not really practical i think on a break down. thanks for the thoughts
06-08-2012 #5UK Plumbersforums Trusted Advisor.
- Apr 2011
- 6,115
- 306
08-08-2012 #6Plumbers Arms member
- Jul 2010
- West Lancashire
- 751
- 133
- Thanked 71 Times in 66 Posts
We used to powerflush hot water units - Turn off mains water into house, connect hot and cold washing machine hoses to
an old pump and header tank filled with boiling water from kettle add chemicals. pump on - Happy days
centralheatking
08-08-2012 #7Steady Plumbing Forum Contributor
- Nov 2010
- North East
- 236
- 14
- Thanked 28 Times in 23 Posts
BG dont powerflush DHW HEX's any more they use a jewellery vibration cleaner along with some DS40, only takes 15 mins for even the most fouled bad boy.
The Following User Says Thank You to FD Powerflow For This Useful Post:
Centralheatking (09-08-2012)
By neily01 in forum Central Heating ForumReplies: 0Last Post: 05-08-2012, 10:45 PM -
To power flush both combi heat exchangers
By Philip123 in forum Plumbing ForumReplies: 4Last Post: 21-04-2011, 06:33 PM -
which are the best heat exchangers in modern boilers
By mike_s in forum Central Heating ForumReplies: 21Last Post: 20-04-2011, 01:20 PM -
Heat exchangers
By grahamep in forum Central Heating ForumReplies: 1Last Post: 08-10-2010, 03:16 AM -
Heat exchangers
By Bernie2 in forum Central Heating ForumReplies: 7Last Post: 16-06-2010, 08:55 AM
1Likes
Heating on upstairs when it is ...
1 Minute Ago in Oil and Solid Fuel Forum
