Results 1 to 15 of 15
Plumbing & Plumbers Forum - Ferroli Modena 80e
Ferroli Modena 80e
Discuss Ferroli Modena 80e in the Central Heating Forum at Plumbers Forums; hi all i have a customer claiming the heating comes on,, on its own!! i have changed the time clock and its still doing it so she says!!! any ideas ...
    Jan 2012
    24
    Default Ferroli Modena 80e
    any ideas ?????????? maybe the pc board
    diamondgas's Avatar
    Newcastle Upon tyne
    6,049
    Default Re: Ferroli Modena 80e
    I'd isolate all external controls cloud! The boiler hex is double tubed, the pump doesn't come on for hot water so there's no way the heating can IMHO
  3. "Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity." Albert Einstein
    Jan 2012
    24
    these no wall stat just the time clock
    diamondgas's Avatar
    Newcastle Upon tyne
    6,049
    Is it the integral one? If so the switch on them gets doddgy! no click to let you know you're in the right position
    Can you not put the control to hot water only on these?
    Jan 2012
    24
    erm yes u can turn the heating stat on the boiler right down to the summer setting, and that
    does the same job
    diamondgas's Avatar
    Newcastle Upon tyne
    6,049
    Is the timer integral?
    Jan 2012
    24
    it is yer
    Jan 2012
    24
    if that means it on the boiler aahahahaha
    diamondgas's Avatar
    Newcastle Upon tyne
    6,049
    Disconnect the mother! and see if the complaint's the same? if not then get a new timer .... ! If it is then that'll be interesting to sort out imho They're double expensive but I'm sure Euroboilers do a cheaper version!
    Jan 2012
    24
    i have already fitted a new time clock!!!!! and it was still the same
    diamondgas's Avatar
    Newcastle Upon tyne
    6,049
    Try turning the heating flow or return iso off under the boiler and see what the reaction is? If the boiler has a pump overrun then there's a chance that there'll be some residue heat pushed into the rads, otherwise they're some obscure demand for heat being generated somewhere!!! IMO
  13. #12
    Jan 2012
    24
    thats why am thinking its the mother board
  14. #13
    diamondgas's Avatar
    Newcastle Upon tyne
    6,049
    Quote Originally Posted by cloud View Post
    I'd have to take a look at the mi's to see if there's a pump overrun. One would cause symptoms you describe to a degree but would not cause the heating to "come on", it'd be on always you'd think?
  15. #14
    east london
    6,666
    has this boiler got a preheat setting that the client has turned on?
  16. #15
    diamondgas's Avatar
    Newcastle Upon tyne
    6,049
    Not ruling it out cloud but it's unusual for a demand for heat to be 'created' from a circuit board IMHO .. not ruling it out, just very strange!
  1. Ferroli Modena 80e
    By Ionkontrol in forum Central Heating Forum
    Last Post: 17-02-2012, 11:50 AM
  2. Ferroli Modena 80E
    By Johnieb in forum Central Heating Forum
    Last Post: 15-02-2012, 10:08 AM
  3. ferroli modena 80e
    By bestmate in forum Plumbing Forum
    Last Post: 11-04-2011, 08:46 PM
  4. ferroli modena 80e
    By Fabby19 in forum Central Heating Forum
    Last Post: 31-03-2011, 11:03 PM
  5. Ferroli Modena 102
    By bono80 in forum Plumbing Forum
    Last Post: 26-11-2009, 04:19 PM
ferroli modena 80e
ferroli modena 80e time clock
ferroli modena 80e faults
ferroli modena
modena 80e
ferroli modena 80e problems
