Page 1 of 5 1234 ... LastLast
Results 1 to 15 of 64
Plumbing & Plumbers Forum - Worcester 28i junior- hot water but no central heating
Like Tree10Likes
Discuss Worcester 28i junior- hot water but no central heating in the Central Heating Forum at Plumbers Forums; Can anyone help, been attempting to fix worcester 28i junior so far fan replaced , pcb replaced, flow sensor replaced but still only have hot water and no central heating, ...
    Jul 2012
    21
    Default Worcester 28i junior- hot water but no central heating
    Can anyone help, been attempting to fix worcester 28i junior so far fan replaced , pcb replaced, flow sensor replaced but still only have hot water and no central heating, when put on for heating pilot fires burners light but after 5-10 mins boiler cuts out.
    Any ideas of which path to take next.
    Thanks in advance
    diamondgas's Avatar
    Newcastle Upon tyne
    6,054
    Default Re: Worcester 28i junior- hot water but no central heating
    to the forum Sammi Brown
    That's one heck of an expense you've shelled out so far, is this your own appliance? When you say "cuts out", what do you mean exactly? Any flashing lights, bells or whistles?
  3. "Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity." Albert Einstein
    Jul 2012
    21
    pilot light flashes, once reset hot water still functions, problem just appears to be heating , can feel pump vibrating but my thinking is its going to vibrate even if its fault due to still trying to work,
    14
    Does the boiler start banging ? These boilers are only low water content so won't take long to start making noises, if so check pump has 240v, sounds like pump
    diamondgas's Avatar
    Newcastle Upon tyne
    6,054
    I take it you're not over familiar with how the boiler operates sammi Brown? However if the appliance is staying alight for 5-10 minutes then you're ruling out a lot of things ... Initially thoughts are that you're describing some kind of blockage or flow restriction? Do any of the radiators warm up? What kind of temp difference do you get between the F&R pipes?
    Plumbing Forum Contributor
    Aug 2011
    65
    fire up in service mode, feel flow and check if the pipe is heating, if its not the diverter valve could be stuck it dhw, causing the boiler to cut out.
    Jul 2012
    21
    no banging noises , had chap look at it but he prefers problems that dont involve alot of fixing
    diamondgas's Avatar
    Newcastle Upon tyne
    6,054
    Quote Originally Posted by Sammi Brown View Post
    Get someone who can be bothered!
    zeebeedee likes this.
    Jul 2012
    21
    u r so helpful diamondgas thankyou
    diamondgas's Avatar
    Newcastle Upon tyne
    6,054
    You're welcome
    What do you mean by "pilot light flashes"? 1/sec or 4/sec ? No doubt you're aware that it makes a difference yeh?
    diamondgas's Avatar
    Newcastle Upon tyne
    6,054
    Bye the way Sammi Brown .... I'll ask the question again, any radiators heating at all? Flow pipe to the radiators getting hot?
  13. #12
    May 2012
    143
    Quote Originally Posted by diamondgas View Post
    You're welcome
    If it's standard efficiency, no diverter, no sec heat exchanger either. I'm 99% sure of this.
  14. #13
    Jul 2012
    21
    no radiators not getting warm / hot / tepid etc
  15. #14
    Jul 2012
    21
    flow pipes hot, return pipes warm but will cut out in approx 4mins
  16. #15
    diamondgas's Avatar
    Newcastle Upon tyne
    6,054
    Quote Originally Posted by Mickyplumb View Post
    You're dead right The standard eff has the flashing fault indicator/reset button Pump works for heating only yeh?
  1. Worcester Greenstar 24i Junior - Hot Water but no Central Heating
    By louca001 in forum Central Heating Forum
    Last Post: 02-09-2011, 12:49 PM
  2. Bosch Worcester 25si No central Heating but Hot water is ok?
    By wingnutta in forum Central Heating Forum
    Last Post: 12-08-2011, 05:26 PM
  3. Worcester greenstar junior 28i heating control
    By slojam100 in forum Central Heating Forum
    Last Post: 30-03-2011, 12:58 PM
  4. Replies: 21
    Last Post: 11-01-2011, 07:46 PM
  5. Worcester 350 - Hot Water Works - Central Heating does not !
    By Cheltenhamhouse in forum Central Heating Forum
    Last Post: 02-10-2010, 09:26 PM
worcester greenstar 24i junior hot water but no heating
worcester boiler hot water but no heating
worcester greenstar 28i junior no central heating
worcester 28i junior no heating
worcester 28i no heating
worcester greenstar 28i junior troubleshooting
