Results 16 to 30 of 64
Plumbing & Plumbers Forum - Worcester 28i junior- hot water but no central heating
Discuss Worcester 28i junior- hot water but no central heating in the Central Heating Forum at Plumbers Forums; Mate I'd ask on here for a Gsr engineer in your area especially if you replaced a flow switch when your heating was the bit playing up, it sounds like ...-
16-07-2012 #16UK Plumbersforums Trusted Advisor.
- Apr 2012
- 1,844
- 153
- Thanked 63 Times in 55 Posts
Re: Worcester 28i junior- hot water but no central heating
Mate I'd ask on here for a Gsr engineer in your area especially if you replaced a flow switch when your heating was the bit playing up, it sounds like you have cost yourself a fortune in the completely wrong areas.
16-07-2012 #17UK Plumbersforums Trusted Advisor.
- Apr 2011
- Newcastle Upon tyne
- 6,050
- 299
- Thanked 769 Times in 743 Posts
16-07-2012 #18Steady Plumbing Forum Contributor
- May 2012
- 143
- 3
- Thanked 7 Times in 7 Posts
16-07-2012 #19New to Plumbing Forum
- Jul 2012
- 21
yes i just switched heating on ran for 4-5mins max , radiators upstairs got warm but downstairs didnt, then pilot goes out but still ignites when demand for hot water , no flashing lights
16-07-2012 #20
16-07-2012 #21New to Plumbing Forum
- Jul 2012
- 21
flame shuts down, but still ignites for hot water demand
16-07-2012 #22Steady Plumbing Forum Contributor
- May 2012
- 143
- 3
I'm guessing then it's not gas lock out. If gas supply can run and keep up with hot water demand, then gas demand on heating demand should be a doddle. I think that if you remove the multiplug (CAREFULLY) from the PCB, then it will override any sensors, thermistors etc. I'm not sure how this helps diagnose but it helped me once on a junior. Let me think for 5 mins.
16-07-2012 #23UK Plumbersforums Trusted Advisor.
- Apr 2011
- 6,050
- 299
I'd be wanting to learn some history about your system Sammi Brown TBH! Has this just happened or been going on for a while? How long?
If recent then more likely to sway towards the pump, If there's an inherent issue then system design ... Are you/have you been filling the system periodically? those kinds of things make a difference when diagnosing circulation problems. Could be a faulty pump or a blockage somewhere. Not sure if these boilers have an integral filter on the heating circuit! If they do it may be as simple as cleaning that out
If your not comfortable working on the plumbing of the boiler I'd advise getting some one else in! There's a place on here I'm looking for a Plumber or Gas Engineer where you can request help and then check out the respondants posts etc. to get a feel of who they are
16-07-2012 #24Steady Plumbing Forum Contributor
- May 2012
- 143
- 3
16-07-2012 #25New to Plumbing Forum
- Jul 2012
- 21
history is changed flow sensor 6 months ago as it developed a leak, other than that this problem has occured in the last month, changed fan due to it being faulty when checking initial problem , changed pcb which had some signs of problems dried cracked solder, prior to changing pcb had no hot water either but since changing pcb have ho****er now but no heating,
16-07-2012 #26New to Plumbing Forum
- Jul 2012
- 21
my thinking is pump just that yes i can feel some vibrations within but dont feel its enough to be functioning properly, was thinking diverter valve but with radiators upstairs getting hot more inclined to think that is working
16-07-2012 #27UK Plumbersforums Trusted Advisor.
- Apr 2011
- 6,050
- 299
16-07-2012 #28UK Plumbersforums Trusted Advisor.
- Apr 2011
- 6,050
- 299
16-07-2012 #29Steady Plumbing Forum Contributor
- May 2012
- 143
- 3
16-07-2012 #30UK Plumbersforums Trusted Advisor.
- Apr 2012
- 1,844
- 153
Kaboom
Worcester Greenstar 24i Junior - Hot Water but no Central Heating
By louca001 in forum Central Heating ForumReplies: 13Last Post: 02-09-2011, 12:49 PM -
Bosch Worcester 25si No central Heating but Hot water is ok?
By wingnutta in forum Central Heating ForumReplies: 3Last Post: 12-08-2011, 05:26 PM -
Worcester greenstar junior 28i heating control
By slojam100 in forum Central Heating ForumReplies: 2Last Post: 30-03-2011, 12:58 PM -
Greenstar 24i Junior not giving hot water, but central heating fine ??
By Toni in forum Central Heating ForumReplies: 21Last Post: 11-01-2011, 07:46 PM -
Worcester 350 - Hot Water Works - Central Heating does not !
By Cheltenhamhouse in forum Central Heating ForumReplies: 2Last Post: 02-10-2010, 09:26 PM
10Likes
There's no stopping this water!
4 Minutes Ago in Plumbing Forum
