Hot water cylinder -
Notices
Old 06-07-2009   #1 (permalink)
shuttlebasher
Info
Default Hot water cylinder
Hi all hope you can help have just fitted a new cylinder moved the central heating pump and motorised valve to suite however filled the system and have heat to the radiators however no hot water has anybody got any ideas i think the motorissed valve is working as can here it kick in
shuttlebasher is offline
Old 06-07-2009   #2 (permalink)
newbie1
Info
Default Re: Hot water cylinder
assuming 3 port mid position valve it is either wired wrong or stuck as the 3 port is hw/ch or mid postn ch and hw
newbie1 is offline
Old 06-07-2009   #3 (permalink)
shuttlebasher
Info
Quote:
If i have tried the manual overide and it still does not work could it be an airlock in the coil in the cylinder?
Old 06-07-2009   #4 (permalink)
Bernie2
Info
The cylinder coil sure can get air locked. But what valve or valves are you using?
Mid position three port, three port diverter, zone valves.
A mid position valve can usually be moved to its mid position and then you would have both legs getting hot. A diverter usually only heats one leg at a time. Zone valves are only electric stop taps so control each leg inidvidually.
If there are no air bleeds about to try for air. Get a bucket if you can and crack the backnut on the hot water side of the valve after making sure the valve is in the right position. This should bleed any air out of the coil, but wait till the system is cold to do it. And be quick or get wet. Watch the carpets and ceiling below.
Its a Plumbers game of chicken.
Bernie2 is offline
Old 06-07-2009   #5 (permalink)
shuttlebasher
Info
Thanks the valve fitted is a Grunfoss Hsa3 just notice when i put the water to heat only ,the radiators are heating up but not the cylinder may be an issue in the way the valve been positioned or i have rewired it wrong will have to check it as for the air locks got my wellies at the ready ...lol
Old 06-07-2009   #6 (permalink)
NickH
Info
I've seen replacement cylinders installed where the new top coil connection sits higher than the old one. If you have just extended the existing pipework upwards to suit, you end up with a air lock in this "loop". If this is the case you have to fit an auto air vent in the top of it.
NickH is offline
Old 06-07-2009   #7 (permalink)
puddle
Info
if you can hear the valve 'kick in' when on hot water mode,valve probably wired incorrectly as no power to valve motor gives you hot water only
A quick test for you to do is turn power off to system this will make sure valve in hot water position ,then remove valve head from body ,then turn power on to allow boiler and pump to operate,hot water should get hot as valve in correct position ,if so wire valve correctly,if rads get hot,valve wrong way round,is nothing gets hot possible air lock
puddle is offline
Old 07-07-2009   #8 (permalink)
shuttlebasher
Info
Thanks Puddle will try that must be something like that as when i switch just the hot water just the heating comes on?
Bungalow with requirement for instant hot water and more water pressure in bathrooms David Salter Showers and Wetrooms 3 06-10-2009 11:56 PM
Hwlo with wold water tank overflowing philwilliams Plumbing Forum 2 13-04-2009 08:57 PM
Hot taps run cold - not the boiler, I reckon... plumb-line Plumbing Forum 4 30-03-2009 09:21 AM
Torrent hot water cylinder problems sasik Plumbing Forum 4 09-03-2009 08:56 AM
Brown hot water Leeky Central Heating Forum 10 14-12-2008 03:50 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80
