Fan noise and repair cost -
Notices
Old 05-07-2009   #1 (permalink)
John Cotton
Info
Default Fan noise and repair cost
My Vokera boiler is making noise but only when on the hot water setting, not the central heating. Its about 14 years old and my plumber says almost certainly the fan and would be very expensive to repair and I should have a new boiler installed.
Any thoughts on his advice ? (this will be the third bolier he's installed for me this year in different houses which makes me wary ?) What should a fan repair cost and would it be false economy ? Thanks for any advice, John
John Cotton is offline
Old 05-07-2009   #2 (permalink)
migoplumber
Super Moderator
migoplumber's Avatar
Info
Default Re: Fan noise and repair cost
it all depends on your point of view. he has allready fault finded the unit. and told you its the fan motor.
personally i dont see how this is possible, however that was not your question.
a fan motor can be rewound and balanced for 150 quid.
if the boiler is old as stated, i wouldnt repair it if it was in my house, i would install a newer more effiecent boiler.
it all depends on how much money you have, and how much your installer knows you have.
sounds like he thinks youve got a bit !!
good luck
shaun
migoplumber is offline
Old 05-07-2009   #3 (permalink)
http://www.ezypart.co.uk/parts/part_id__15
Most expensive fan I've replaced was £155 + vat and that was because it had it's own pcb that you couldn't split,they are normally not that dear.Don't know your model from your post and have obviously not seen the job,so can't tell you if the rgi's diagnosis is correct but I think you should get a second opinion.If your boiler is as old as you say he may be thinking along the energy efficeincy route,saving you more in the long term by changing rather than repairing
jpm is offline
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80
