Chatrooms
Open vent "pumping" over -
Notices
Old 05-07-2009   #1 (permalink)
petethefeat
Info
Default Open vent "pumping" over
I have just replaced a Gledhill systerm mate 2000 with a Boilermate BP, the heating (and hot water) systems are open vented. I have a small amount of water discharging from the heating vent pipe when the pump stops! I believe the pipe work configuration is correct. Does anyone know if this will cause a problem?
petethefeat is offline
Old 05-07-2009   #2 (permalink)
migoplumber
Super Moderator
migoplumber's Avatar
Info
Default Re: Open vent "pumping" over
gledhill systemmates are an ingenious bit of kit, i dont like them personally, but they are quite clever.
the boiler mate i dont know.
all i would suggest, if you are replacing the systemate. label all pipework, remove unit. treat it as a new installation with existing pipework.
shaun
migoplumber is offline
Regular Auto Air Vent Failure, Any Ideas? stephens Central Heating Forum 4 22-04-2009 10:42 PM
Best air vent or seperator SmogLee Central Heating Forum 4 05-03-2009 09:01 PM
Central heating Queries. Open vented conventional S-Plan system. Logic Plumbing Forum 4 04-02-2009 11:57 AM
leaking auto air vent valve sasik Plumbing Forum 3 30-01-2009 07:23 AM
Size of waste vent pipe Drew1000 Plumbing Forum 3 20-07-2008 08:53 PM
