Results 1 to 12 of 12
Plumbing & Plumbers Forum - How do I clear an airlock in the central heating system after refilling?
  • 1 Post By gary
Discuss How do I clear an airlock in the central heating system after refilling? at UK Plumbers Forums; Hi all What is the best way to get rid of an airlock on a F&E system as I have drained down the system and then refilled after changing a ...
    South-East London/Kent
    132
    Default How do I clear an airlock in the central heating system after refilling?
    Hi all
    What is the best way to get rid of an airlock on a F&E system as I have drained down the system and then refilled after changing a few rads to new ones?
    I've bled all the rads i.e starting with the ground floor ones and then making my round to all the other rads on the bedroom and landing level?
    Do I have to drain down again?? Any ideas and how to do it are much appreciated!
    Many thanks
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,927
    Default Re: How do I clear an airlock in the central heating system after refilling?
    did you lock open the three/two port when refilling?
    The Turtle Moves
    946
    Have you opened all radiator valves,are all radiators affected
    395
    Last time this happened to me I put a garden hose on the drain point and blasted mains water in the the pipework this cleared it. Open vented always a pain for air locks!
    mountainman's Avatar
    Jan 2012
    Essex
    4,735
    Is there an air bleed valve on a standpipe next to the motorised valve(s) that you have forgotten to bleed?
    Banned
    Mar 2009
    Liverpool
    1,983
    Fill slowly helps. Turn on pump but not boiler and close rad's all rads except furthest away. Do not let pump run dry. The idea is that the pump will push the water around the furthers part of the system then work back turning on and bleeding rads as you do. Can do it the other way as well. If the airlock is down the cold feed try blowing down the vent. You can sometimes crack the cold feed pipe union at the boiler and let air out. It all depends on where it is.
    132
    Hi all
    I think its a combination of the lot to be fair!
    1. The bathroom rad isn't getting hot and have bled every single radiator including that one!
    2. I believe this system has a two 2x2 port valves so is it ok to move switch across without doing damage? So no I haven't open them in this case or closed them.
    3. I think there is a bleed valve on the vertical standpipe by the HWC but it looks lime scaled up and with a green tinge which I didn't want to open in case I caused a mini flood and couldn't close it again! - Am I ok to open this?
    Is it ok to use the hose pipe main like Duncan said above as I would wanna damage any components in the system especially if 2 port vales were closed etc?
    Many thanks to all for your time
    Martyn
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,720
    Manually open both 2 ports, the lever is normally in the auto position but can be moved to the manual open position. vent from air vent, and the bleed screw on front of pump. job done
    132
    Again - thanks to all for being very informative!
    This forum can be invaluable
    Member Paulus's Avatar
    Oct 2010
    Cheshire
    1,080
    Yes I've done it many times and it usually clears the airlock.
    If we find we cannot help others, the least we can do is to desist from harming them. Dalai Lama.
    quality's Avatar
    Sep 2009
    South Yorkshire
    3,641
    Slowly slowly catchy money and as eco suggested both valves manual. It can take a while
    36
    Use your wet vac on the vent pipe! Suck out the blockage.
    tommy1712 likes this.
  1. Refilling Sealed System
    By Mrast in forum Central Heating Forum
    Last Post: 16-10-2013, 06:24 PM
  2. Replies: 2
    Last Post: 26-02-2013, 09:58 PM
  3. Refilling Central Heating - Problems to be expected...
    By Jimmy Thew in forum Central Heating Forum
    Last Post: 09-12-2012, 03:51 PM
  4. Nearly no hot water and heating since refilling system
    By wickers in forum Plumbing Forum
    Last Post: 10-01-2012, 08:14 PM
  5. Central Heating System
    By leslie50 in forum Plumbing Forum
    Last Post: 30-07-2011, 11:53 AM
  6. Central Heating not working...airlock?
    By Michelle1972 in forum Plumbing Forum
    Last Post: 28-11-2010, 09:10 PM
  7. How can I sort out an airlock in a customer's heating system?
    By The Plumber Guy in forum Plumbing Forum
    Last Post: 06-09-2010, 03:30 PM
  8. central heating system
    By 19bri79 in forum Plumbing Forum
    Last Post: 27-02-2010, 05:37 PM
  9. refilling a central heating system
    By cherryb in forum Central Heating Forum
    Last Post: 18-10-2008, 09:29 PM
  10. New central heating system
    By bitsandbobs in forum Central Heating Forum
    Last Post: 22-04-2008, 09:31 AM
airlock in central heating
airlock in central heating system
central heating airlock
airlock in heating system
how to clear an airlock in central heating system
