Plumbing & Plumbers Forum - Changing gravity fed hot water pumped heating to vailaint ecotec pro 28 combi
Discuss Changing gravity fed hot water pumped heating to vailaint ecotec pro 28 combi in the Central Heating Forum at Plumbers Forums; Hi everyone would appreciate any ideas on the above system. I have just passed my gas safe and my sister wants me to convert her system to the one above. ...-
10-05-2012 #1Plumbing Forum Contributor
- Nov 2011
- 67
- 35
- Thanked 1 Time in 1 Post
Hi everyone
I have just passed my gas safe and my sister wants me to convert her system to the one above. (good place for me to practice)
is there anything I should look out for..... I have already warned her that sealing and open vent system may cause leaks.
also i'm changing her rads- would you powerflush withthe new rads on or change them once it is powerflushed. I normally change to new rad valves before flushing but this wouldn't make sense if i was then going to change the rads after.
thanks for your help.
10-05-2012 #2UK Plumbersforums Trusted Advisor.
- Hastings
- 4,023
- 47
- Thanked 405 Times in 375 Posts
Re: Changing gravity fed hot water pumped heating to vailaint ecotec pro 28 combi
If there is any pipe under solid floors don't convert it's asking for trouble. If the old system is still working chuck some cleaner in for a couple of weeks before you start of it's possibe. Disconnect the rad circuit and give it flush on it's own before the new boiler goes in to get rid of as much muck as possible then fit the new rads and boiler before giving another flush. Fit some sort of system filter because you will never get all of the muck out of the system.
The Following User Says Thank You to Mike Jackson For This Useful Post:
lordyjordy111 (12-05-2012)
10-05-2012 #3Plumbers Arms member
- Dec 2011
- Somerset
- 1,826
- 94
- Thanked 185 Times in 180 Posts
I'd definatly avoid presurising a system with any pipework under a solid floor as Mike says, it may be ok, but if its not then you're in for loads of fun with a kango digging the floors up!
Do vailant still do an open vent combi? Failing that you can run the Intergas combis on a open vent system.
The Following User Says Thank You to Roger Welton For This Useful Post:
12-05-2012 #4Plumbing Forum Contributor
- Nov 2011
- 67
- 35
hi mike
there is no pipe work in the screed they all seem to be on drops....... still thinking seal it???
what cleaner would you chuck in for the two weeks
thanks to everyone for the advice
12-05-2012 #5UK Plumbersforums Trusted Advisor.
- Hastings
- 4,023
- 47
I'd chuck Fernox F3 in and let it rattle round the system. Fernox told me it remains active for around 4 weeks.
Sent from my iPad using Tapatalk HDGas Safe Registered Engineer for all your Domestic gas, Heating and plumbing needs in Hastings, East Sussex. Check me out on the Gas Safe website, reg. No. 537192.
12-05-2012 #6Plumbers Arms member
- Mar 2012
- 2,087
- 107
- Thanked 82 Times in 80 Posts
x400 if not ,
as been stated defo get as much muck out as possble , try stick the filter somewhere where it cant be seen or out the way as the are ugly !
The Following User Says Thank You to hammers4spanner For This Useful Post:
12-05-2012 #7Plumbers Arms member
- Dec 2011
- Somerset
- 1,826
- 94
If its all on drops then nay problems should be easy(ish) to get to to repair, your already changing the rads, make sure you do the valves at the same time and you should be good to go.
Flushing, if the system is working now, as above, either x400 or f3 in for a few weeks before, then again on completion, I always fit a magnaclean for ongoing protection.
Is my system fully pumped or part pumped/gravity?
By Wintersun in forum Central Heating ForumReplies: 7Last Post: 26-12-2011, 11:27 AM -
gravity hot water not working, pumped central heating working
By njk in forum Central Heating ForumReplies: 9Last Post: 18-12-2011, 12:24 PM -
Converting Gravity Hot Water & Pumped Heating to Fully Pumped System
By T&Earth in forum Central Heating ForumReplies: 3Last Post: 16-12-2010, 06:34 AM -
Gravity hot water to fully pumped but keeping same boiler for now.
By thekidda in forum Central Heating ForumReplies: 2Last Post: 25-10-2010, 06:50 PM -
Changing to Fully Pumped .
By verdigrey in forum Central Heating ForumReplies: 3Last Post: 07-02-2010, 05:26 PM
How???????????
6 Minutes Ago in General Off-Topic Chat
