Results 1 to 6 of 6
Plumbing & Plumbers Forum - Worcester 24i RSL - No ignition!
Discuss Worcester 24i RSL - No ignition! in the Central Heating Forum at Plumbers Forums; New PCB and bottom panel fitted, pump running, fan running, pressure switch working but no ignition. Old PCB was damaged due to owner having clamped it to the bottom panel. ...
    MMB
    MMB is offline
    14
    Default Worcester 24i RSL - No ignition!
    Discussed with Worcester technical who advised just to check for breakages in wiring, all checked ok.
    Any ideas on why still have no ignition?
    Hampshire
    196
    Default Re: Worcester 24i RSL - No ignition!
    Have you checked spark gap (check M.I's), is it clean. Continuity check on spark lead?, spade connectors clean and making good contact. Has the right spark igniter been used. (diff app but correct spark igniter was cranked, one in place was straight and was sparking to thermocouple). Just a few basic ideas that might help, havent done much work onn that boiler
  3. The Following User Says Thank You to lambchop For This Useful Post:
    MMB (13-05-2012)
    MMB
    MMB is offline
    14
    Yes done all, still no luck
    Hampshire
    196
    All plugs on pcb on tight & right, any internal fuses, are they ok not muvh help but hopefully some of the really experienced guys will post
    diamondgas's Avatar
    Newcastle Upon tyne
    6,054
    Heard of a 24i RSF, is it this boiler? If so have you checked the overheat hasn't tripped? Re-set button on the top of the boiler
    However if pump & fan running & no ignition, check for power to the gas valve. If that's present then there are other checks that are not for the eye's of none GSR readers in this forum alas
    If you have no joy, pm me your GSR number and I can maybe be help you out some more...
    Steve
  7. The Following User Says Thank You to diamondgas For This Useful Post:
    MMB (13-05-2012)
  8. #6
    MMB
    MMB is offline
    14
    Quote Originally Posted by diamondgas View Post
    Steve
    Your a legend Steve Re-set button it was! Cheers
    regards Mike.
  1. Worcester 24i ignition probs
    By Dockie in forum Central Heating Forum
    Last Post: 09-01-2012, 08:04 AM
  2. Worcester 30cdi combi hw ignition problems
    By Fab1 in forum Plumbing Forum
    Last Post: 10-12-2011, 03:32 AM
  3. Worcester 24i rsf ignition problem
    By mattyharris in forum Central Heating Forum
    Last Post: 15-11-2011, 10:36 AM
  4. worcester 28 he intermittent explosive ignition
    By buckley plumb in forum Central Heating Forum
    Last Post: 30-01-2011, 09:57 AM
  5. Worcester 24i ignition problems???
    By jimpop in forum Plumbing Forum
    Last Post: 26-11-2010, 11:00 AM
worcester 24 i ignite switch
worcester 24i no ignition
worcester 24i no spark
worcester 24i rsf no ignition
worcester 24i rsf fan running with hot water but not ch
worcester 24i panel
worcester 24i rsf
