Results 1 to 4 of 4
Plumbing & Plumbers Forum - Building temperature rise rate
Discuss Building temperature rise rate in the Central Heating Forum at Plumbers Forums; Hi, Is there a recommended temperature rate increase rate for a correctly sized ch system. i.e x degrees per hour? - say if building is at 10deg, how long should ...-
27-04-2012 #1Banned
- Oct 2011
- 95
- Thanked 2 Times in 2 Posts
i.e x degrees per hour? - say if building is at 10deg, how long should it take to get to 18 degrees?
27-04-2012 #2Top Plumbing Forum Contributor
- Oct 2010
- Cheshire
- 662
- 51
- Thanked 97 Times in 94 Posts
Re: Building temperature rise rate
Not that I am aware. But then I seem to be unaware of lots of things.
27-04-2012 #3
no set rate so im aware of
www.blockeddrainsbirmingham.co.uk
http://mzrplumbing.blogspot.co.uk/
www.emergency-plumberbirmingham.co.uk
http://www.blockeddrainsbirmingham.co.uk/blog/wp/
Discussion contents reflect the views of individual participants only. MZR Plumbing & Drainage and its owner organizations bear no responsibility for accuracy of participant comments and will bear no legal liability for discussion results.
27-04-2012 #4UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,348
- 281
- Thanked 1,176 Times in 1,043 Posts
No because every building is different in design, made of different materials, have different windows and insulation levels and loose heat at different rates.
Get an optimising programmable stat and it will learn how long it takes and automatically adjust the switching times accordingly.
Combi Pressure Rise
By Ceri in forum Central Heating ForumReplies: 10Last Post: 03-02-2012, 05:14 PM -
Temperature Rise at Night
By tonym191 in forum Central Heating ForumReplies: 2Last Post: 13-01-2012, 10:58 AM -
Gas prices to going to rise, the rise is being blamed on the forced green agends
By Rob Sale in forum General Off-Topic ChatReplies: 7Last Post: 20-11-2011, 08:52 AM -
pressure rise with dhw
By lost in forum Central Heating ForumReplies: 3Last Post: 14-06-2010, 09:12 PM
2Likes
Taken to the cleaners...! Please...
1 Minute Ago in Insurance for Plumbers
