Results 1 to 2 of 2
Plumbing & Plumbers Forum - tp ikon mid position valve
Discuss tp ikon mid position valve in the Central Heating Forum at Plumbers Forums; Hi everyone new to this forum so here goes travis perkings ikon mid position valve anyone knows who make it and what model number etc, better still do they still ...-
25-04-2012 #1New to Plumbing Forum
- Nov 2010
- 3
better still do they still stock it
help would be great
cheers
26-04-2012 #2Plumbing Forum Contributor
- Aug 2010
- lancs
- 61
- Thanked 5 Times in 5 Posts
Re: tp ikon mid position valve
they still do them think they have changed the name of them any 3 port will fit but you may need to change the nuts of your old pipe work to suite the thread of the new valve, best way to find out is take the old valve off and try the new nut and olive on the new 3 port if it winds all the way on by hand the old nuts on the pipe work will be fine to use, second tip is when re wiring it take 1 wire out at a time and fit the new 1 in its place ! the valve ive found is 985630 called iflo now link below:
http://www.travisperkins.co.uk/wrms/...g_Controls.pdf
Mid-position valve problem
By Lolhend in forum Central Heating ForumReplies: 5Last Post: 19-01-2012, 08:46 PM -
mid position valve
By desrob in forum Central Heating ForumReplies: 0Last Post: 07-12-2011, 07:56 PM -
mid position valve wiring s
By desrob in forum Central Heating ForumReplies: 1Last Post: 16-09-2011, 10:29 PM -
mid position valve gone?
By samtheplumber in forum Plumbing ForumReplies: 4Last Post: 15-06-2011, 07:45 PM -
3 position valve problems
By dbharrison in forum Valves & TapsReplies: 1Last Post: 13-12-2010, 03:02 PM
Link Exchange - Plumbing Site
6 Minutes Ago in Links, Forum Updates, News and Site Suggestions
