Results 1 to 4 of 4
Plumbing & Plumbers Forum - hot water tank
hot water tank
Discuss hot water tank in the Central Heating Forum at Plumbers Forums; not getting any hot water from tank , heating system is in large house made into flats top floor flat has a hot water cylinder with coil inside , the ...-
22-04-2012 #1New to Plumbing Forum
- Sep 2011
hot water tank
not getting any hot water from tank , heating system is in large house made into flats top floor flat has a hot water cylinder with coil inside , the multi point boiler sysem is heating the radiators in the flat ok but not the hot water cylinder , there is a thermostat on the tank linked to a celonoid valve which i am told by an electrician is working ok , could the coil in the tank have a blockage ?? or couid there be some sort of other problem, can anyone help !
22-04-2012 #2UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,738
- 297
- Thanked 374 Times in 357 Posts
Re: hot water tank
Feed and expansion tank could have run dry. Ball valves can stick in the shut position causing this fault. If you have access to the loft or place where it is, move up and down a couple of times and should sort out the problem, hopefully.
22-04-2012 #3Plumbers Arms member
- Mar 2012
- London
- 1,285
- 23
- Thanked 75 Times in 70 Posts
Re: hot water tank
Could be a faulty 2/3port valve..
GSR engineer based in south east London
22-04-2012 #4UK Plumbersforums Trusted Advisor.
- May 2008
- Bolton
- 4,191
- 190
- Thanked 352 Times in 332 Posts
Re: hot water tank
are you getting cold water from hot taps or no water from hot taps?
Loft water tank - weight of 100 gallon tank - ok?
By JDX in forum Plumbing ForumReplies: 6Last Post: 2 Weeks Ago, 07:00 PM -
Cold water tank used as F&E tank.
By MickBrown in forum Central Heating ForumReplies: 4Last Post: 07-01-2012, 07:18 PM -
Central heating Expansion tank is getting back flow of water from hot water tank
By ozi in forum Central Heating ForumReplies: 4Last Post: 28-11-2011, 12:04 AM -
C/H header tank feed pipe pushing hot water into tank
By RON in forum Central Heating ForumReplies: 11Last Post: 16-06-2008, 09:57 PM -
By RON in forum Central Heating ForumReplies: 0Last Post: 05-06-2008, 11:19 PM
fridge magnets
