Plumbing & Plumbers Forum - Glow worm ultimate 40ff not sparking
Discuss Glow worm ultimate 40ff not sparking in the Central Heating Forum at Plumbers Forums; Hi I have a problem with the above boiler, it's not sparking or lighting at all. When I turn it on I can hear a humming noise and it clicks ...-
16-04-2012 #1New to Plumbing Forum
- Apr 2012
Hi
I have a problem with the above boiler, it's not sparking or lighting at all. When I turn it on I can hear a humming noise and it clicks on but I can't see any spark and it doesn't light. Have checked pilot is not blocked and also tried replacing the ignition and the pcb, both of which have made no difference.
Te fan has been very noisy recently so could this have failed & be the cause? Is there anyway I can't test this or bypass it to test as its quite an expensive part to replace if that's not the cause?
Thanks,
Lee
16-04-2012 #2UK Plumbersforums Trusted Advisor.
- Nov 2011
- Beautiful Barlick
- 5,360
- 291
- Thanked 378 Times in 372 Posts
Re: Glow worm ultimate 40ff not sparking
hi are you gsr ? maybe you need to get a gsr in before you waste more money throwing bits at this boiler
>>>>>>>>>>GSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply
I'M DANCIN, YOU ASKIN ?
16-04-2012 #3Plumbers Arms member
- May 2009
- 7,303
- 218
- Thanked 681 Times in 604 Posts
As said,think maybe you are at the point were you should maybe think about getting someone in who knows what they are doing and meets the legal requirements for working on gas appliances
imho
glow worm ultimate 40ff/lp
By MP plumb in forum Plumbing ForumReplies: 7Last Post: 04-03-2012, 10:07 AM -
Glow worm micron 40ff constant pressure loss!
By sniperkmydj in forum Central Heating ForumReplies: 6Last Post: 29-01-2012, 07:12 PM -
glow worm micron 40ff problem
By Mpb-10 in forum Central Heating ForumReplies: 8Last Post: 01-01-2012, 10:08 PM -
Glow Worm Micron 40ff boiler problems
By unibumuk in forum Plumbing ForumReplies: 0Last Post: 08-12-2011, 11:46 AM -
Glow worm ultimate
By GAZZA19 in forum Plumbing ForumReplies: 5Last Post: 10-01-2011, 08:23 PM
2Likes
Gas installers workmate
11 Minutes Ago in Gas Safe Register Forum - Public Forum
