Results 1 to 15 of 18
Plumbing & Plumbers Forum - never seen this fault, any ideas?
Discuss never seen this fault, any ideas? in the Central Heating Forum at Plumbers Forums; Can't remember the correct name for them but the cyliners that have like a half cylinder on top that acts as a f+e tank, faucet mabee? Anyway, customer said they ...-
16-04-2012 #1
Anyway, customer said they were getting hot water out of all the cold taps in the house bar the kitchen one that is mains fed.
I checked the cyliner stat was set correctly and the 3port was switching on/off ok.
Does anyone have any other ideas what could be causinfg this? thanks
16-04-2012 #2
Re: never seen this fault, any ideas?
Elson tank??
16-04-2012 #3UK Plumbersforums Trusted Advisor.
- Oct 2010
- Northampton
- 6,058
- 595
- Thanked 290 Times in 280 Posts
Mixer or cylinder is getting over heated !and pumps over and heats up the cold water in the up part of the cylinder
The Following User Says Thank You to SafeGasInstall For This Useful Post:
southcoastboile (16-04-2012)
16-04-2012 #4Plumbers Arms member
- May 2009
- 7,303
- 218
Someone turned on the old immersion heater by mistake and thermostat gone maybe
The Following User Says Thank You to Puddle For This Useful Post:
16-04-2012 #5Top Plumbing Forum Contributor
- Apr 2011
- 751
The stat might be set but it may not be working(have you checked this)
The Following User Says Thank You to glenno1 For This Useful Post:
16-04-2012 #6
What would make it overheat though?
16-04-2012 #7
My mate fitted a new stat, will check operation tomorrow, thats an idea. Any more? good replies so far, gives me a few things to look at
16-04-2012 #8UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,397
- 281
- Thanked 1,180 Times in 1,047 Posts
Cold supplies to bathrooms should not be fed from a combination tank as they will heat up and it sounds like this is what has been done.
Just swap it to mains cold through out the house.
16-04-2012 #9
16-04-2012 #10UK Plumbersforums Trusted Advisor.
- Oct 2010
- Northampton
- 6,058
- 595
Is cold water hot out of all taps in the house ?
16-04-2012 #11
16-04-2012 #12Steady Plumbing Forum Contributor
- Jan 2012
- North West
- 122
- Thanked 3 Times in 3 Posts
Is it a fortic cylinder ??
16-04-2012 #13
combination cylinder, elson and fortic are just brand names, i think
16-04-2012 #14UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,397
- 281
Sounds as if it is
One of these type
Cold supplies should never be taken from one of these as the heat rises straight into the cistern.
Not much to stop the heat transfer in there!
16-04-2012 #15
yes all taps apart from cold in kitchen which is mains fed. Thanks Tamz, didn't think of changing it to mains next to the cylinder, kind of obvious now you've said it, ill recomend they do that.
any ideas?
By barryplumb in forum Valves & TapsReplies: 5Last Post: 13-10-2011, 02:29 PM -
Any ideas?
By mjt in forum Plumbing ForumReplies: 6Last Post: 19-07-2011, 03:49 PM -
any ideas???
By Rodreguez in forum Central Heating ForumReplies: 17Last Post: 19-04-2011, 03:42 PM -
Any ideas on this fault
By ballandco in forum Gas Safe Register Forum - Public ForumReplies: 1Last Post: 12-04-2011, 09:14 PM -
Any Ideas what this is?
By Whoremoan in forum Plumbing ForumReplies: 5Last Post: 10-08-2010, 05:54 PM
1Likes
price guides
