Results 1 to 12 of 16
Plumbing & Plumbers Forum - Pressure gauge keep creeping up to 2bar.
Discuss Pressure gauge keep creeping up to 2bar. in the Central Heating Forum at Plumbers Forums; Hi all, wonder someone can shed some lights to this, the gauge on my boiler (Valliant turbomax combi) keep increase to around 2bar. I bled the radiators and drain out ...
    Jan 2012
    135
    Default Pressure gauge keep creeping up to 2bar.
    Hi all, wonder someone can shed some lights to this, the gauge on my boiler (Valliant turbomax combi) keep increase to around 2bar. I bled the radiators and drain out some of the radiators water brought the pressure down to under 1bar but when the heating comes on for about 1 hr the gauge shows nearly 2bar. Tried this a few times, still the same. Could this be an expansion vessel fault in the boiler?
  2. something I do on the side I am trying
    www.myfootballgifts.co.uk my site!
    www.kokio.co.uk my wife's site!
  3. #2
    Howsie's Avatar
    2,994
    Default Re: Pressure gauge keep creeping up to 2bar.
    Up to 2bar isn't a problem. The water expands when it's heated and its natural to see a pressure increase.
    If it continues to increase it would seem that you're filling loop is connected and letting bye.
    Banned
    Dec 2009
    Portsmouth
    672
    If the exp vessel was faulty, or needed recharging, then the pressure would normally shoot up quite rapidly.
    Mar 2012
    Bolton
    942
    If the filling loop was letting by, the system pressure would also rise when not in use, so easy diagnosis for that one - turn heating off, let it cool down, is it still rising?
    dontknowitall's Avatar
    Apr 2008
    South Shropshire
    6,082
    If you remove the filling loop you'll soon know whether it or the fittings around it are at fault. If it's not letting by then it's most likely to be the expansion vessel.
    I'm not a complete idiot; some parts are missing
    Jan 2012
    135
    Default
    Thx guys. Will recheck to see if it's letby although that was the first thing I checked and the valve was shut.
    Apr 2008
    South Shropshire
    6,082
    Aye - the valve may well be shut but it might not have isolated the water - if you remove the filling loop you'll see if it's letting some through.
    Whn1's Avatar
    Mar 2012
    London
    1,295
    Does it stop at 2bar?
    GSR engineer based in south east London
    Jan 2012
    135
    Default
    Can't remove filling loop
    as it is built in. Yes it stop at around 2 bars - u got some idea?
    Howsie's Avatar
    2,994
    Default
    How many rads do you have?
    EX VI TERMINI
    Howsie's Avatar
    2,994
    Default
    Stops at 2 bar, no problem.
    EX VI TERMINI
  13. #12
    Jan 2012
    135
    Default
    10 rads.
  1. Filling loop pressure gauge
    By M.Joshi in forum Central Heating Forum
    Last Post: 16-04-2012, 11:16 PM
  2. CH pressure gauge fluctuates between 0 and 1 bar?
    By BAAZ in forum Plumbing Forum
    Last Post: 14-11-2011, 10:42 PM
  3. How do I adjust my pressure gauge?
    By eric.e in forum Central Heating Forum
    Last Post: 15-12-2010, 05:39 PM
  4. pressure gauge
    By pauls in forum Plumbing Tools
    Last Post: 06-12-2010, 06:46 PM
  5. Pressure Gauge not responding to refill
    By wizardsaleem in forum Plumbing Forum
    Last Post: 17-07-2009, 11:15 AM
boiler pressure guage creeping up
central heating pressure creeps up
boiler pressure gauge creeps up
