Results 1 to 15 of 26
Plumbing & Plumbers Forum - British Gas 330 (Glow Worm)
Like Tree7Likes
Discuss British Gas 330 (Glow Worm) in the Central Heating Forum at Plumbers Forums; Hi, I have a British Gas 330 condensing boiler (manufactured by Glow Worm). I've been plasterboarding today and removed the downstairs light fitting and although the downstairs lighting circuit was ...
    Dec 2009
    26
    Default British Gas 330 (Glow Worm)
    I have a British Gas 330 condensing boiler (manufactured by Glow Worm). I've been plasterboarding today and removed the downstairs light fitting and although the downstairs lighting circuit was off at the consumer unit I think because I touched the neutral and earth together the whole upstairs circuit RCD tripped. I flipped it back up and all seemed OK. The boiler is on the same upstairs RCD and I noticed this evening that the boiler was off but the programmer was still on and everything up to the fused spur was fine, so I presume there must be something wrong with the boiler.
    The boiler had been working this morning and we've never had a problem in three years. I presume when the RCD tripped it's somehow blown something inside the boiler but what confuses me is why didn't the boiler circuit RCD or fuse in the spur trip out before it got to the boiler?
    Is this likely to be something as simple as a blown fuse inside the boiler?
    SafeGasInstall's Avatar
    Oct 2010
    Northampton
    6,058
    Default Re: British Gas 330 (Glow Worm)
    change fuse at fuse spure with another a 3 amp one
  3. The Following User Says Thank You to SafeGasInstall For This Useful Post:
    ma701ss (16-04-2012)
    diamondgas's Avatar
    Newcastle Upon tyne
    6,051
    I hope it's just the fuse ma701ss I think it's this model Glow-Worm that the main pcb doesn't like to be interrupted. I had a glow worm do just that on a pal last year. He turned the spur off to do some work on the system and when it came to turn it back on it wouldn't start-up! Had to replace the main circuit board. I'm scratching my head but can't remember the model. I'll see if i can find the paperwork for it and get back to you
    diamondgas's Avatar
    Newcastle Upon tyne
    6,051
    Found the job ---- GlowWorm 38cxi .. I think the BG330 is different but maybe inherited the same issue? The display was dead on the one I worked on.
    Dec 2009
    26
    Hi, thanks for the replies. I'd already checked the 3A fuse and it was fine. The programmer works when the fused spur is on. I also checked thew 630mAT fuse inside the boiler and it's intact. Must be the PCB or something then? Anyone know where I can get a cheap one from, or suggest the best way to get this repaired without being ripped off?!
    M.Joshi
    Sounds to me like a fundamental design flaw - have you tried contacting British Gas or Glow-Worm?
    diamondgas's Avatar
    Newcastle Upon tyne
    6,051
    If the display is dead then maybe it's a related issue ... Honestly I just wouldn't know? Whereabouts are you in the UK? Post a request up here I'm looking for a Plumber or Gas engineer. You can then vet via pm's whoever replies
    dancinplumba likes this.
  9. The Following User Says Thank You to diamondgas For This Useful Post:
  10. #8
    Kev the gas's Avatar
    West Sussex
    600
    As the man above said, before any more damage is caused.
    These new boilers are the work of the Devil !!!!!!!!!!!!!!!!!!!
    diamondgas and dancinplumba like this.
    safe-gas-installer.co.uk
  11. #9
    Dec 2009
    26
    I'm in SE London. Will take a look at that forum, thanks.
  12. #10
    diamondgas's Avatar
    Newcastle Upon tyne
    6,051
    Quote Originally Posted by ma701ss View Post
    Good luck ma701ss ... there's some decent folk who know there stuff on here ... If you get any pm's just click on their 'nick' and you'll get an idea of their knowledge and ask them whatever you need to know
  13. #11
    Dec 2009
    26
    Any idea though why something inside the boiler would fail if the central heating circuit RCD didn't trip, the 3A fuse hasn't blown and the boiler fuse also hasn't blown? It must have been when I tripped the RCD to the entire upstairs circuit because the boiler hasn't faild in 3 years, but it presumably shouldn't have caused any damage to the boiler.
  14. #12
    diamondgas's Avatar
    Newcastle Upon tyne
    6,051
    I'd be guessing ma701ss ... honestly ! PCB's have within so many switches and relays that may well burn out when power is interrupted then restored...... Just think of a lightbub, how many times has it faithfully lit up when you've flicked the switch then on one occasion pop! Or 'bang' Or all the lights go out....! One of those things I guess
    Kev the gas likes this.
  15. #13
    Oct 2010
    Northampton
    6,058
    How did you check the fuses ? Continuity test ? Have checked boiler for reverse polarity ? Removed pump yesterday which was changed 15 years ago ,Was wired up in corect L to live on pump N to earth on pump E to neutral on pump Lucky no fatality for 15 years !Ps I am in London too if need help !
  16. #14
    Dec 2009
    26
    Quote Originally Posted by SafeGasInstall View Post
    Hi, I checked the fuse simply by noting the wire inside appeared to be intact. It's a pretty thick wire and I could see it clearly. I'm in Bromley.
  17. #15
    M.Joshi
    Post Re: Testing a fuse
    Visual inspection may not reveal any tiny breaks. The fuse in the spur shouldn't be transparent - how did you check that?
    If you don't have a multimeter/continuity tester, you can use a working torch. Unscrew the battery compartment cap and place the fuse inbetween the battery end and the metal contact on the torch barrel. There is a diagram showing this on the following website:
    Electricity Safety | Plugs and Fuses | Replacing a Fuse | Northern Ireland | RoSPA
  1. Glow worm 24 cxi
    By MZR in forum Central Heating Forum
    Last Post: 19-03-2012, 09:17 AM
  2. Glow worm 30 cxi
    By localyokel in forum Central Heating Forum
    Last Post: 30-12-2011, 09:45 AM
  3. glow worm 38 cxi
    By chelsea in forum Gas Safe Register Forum - Public Forum
    Last Post: 22-11-2011, 06:05 PM
  4. glow worm cxi
    By buckley plumb in forum Central Heating Forum
    Last Post: 27-09-2011, 05:35 PM
  5. Glow worm 45-60
    By bikerbas in forum Central Heating Forum
    Last Post: 17-08-2010, 01:17 PM
british gas 330 boiler manual
glowworm 330
british gas 330 manual
british gas 330
glow worm 330
glow worm british gas 330
