Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Plumbing & Plumbers Forum - Logic Combi 35 F1 Error
Discuss Logic Combi 35 F1 Error at UK Plumbers Forums; Hello all, Came home this evening to discover my heating wouldn't turn on, and I can't get any hot water either. I noticed I have an F1 - "Low Water ...
    Apr 2012
    10
    Default Logic Combi 35 F1 Error
    Hello all,
    I noticed I have an F1 - "Low Water Pressure" fault displaying on the boiler.
    I've followed the instructions in the manual, and in other threads in this forum, opened the blue & black valves, but the pressure gauge doesn't seem to move at all when I do this... Any other suggestions? It's pretty damn cold!
    Thanks in advance for any help you can provide :-)
    Jul 2009
    Yorkshire
    405
    Default Re: Logic Combi 35 F1 Error
    boiler needs water topping up mate should read 1 on the gauge on the left had side under boiler you need to top it up using the filling loop (looks like a flexi tap connector)
    moogwai's Avatar
    Dec 2009
    birmingham
    1,346
    Default
    Quote Originally Posted by northcarr View Post
    Agreed.
    Sent from my MB526 using Tapatalk
    Apr 2012
    10
    But the filling loop was attached already, all I need to do is open both valves surely? But the gauge doesn't move at all.
    west midlands
    1,401
    Since there are 2 valves , 1 may have been already on
    ( Not how it should be left - but its fashonable not to Follow Instructions ..these days )
    Have it nice and quiet , then may be able to hear start of water flow , Don't over do that guage !
    Jul 2009
    Yorkshire
    405
    some filling loops have a shut off at both ends usualy sloted screw type make sure both are open to allow the water through
    Jan 2011
    146
    I have had the plastic lever turn but not turn the brass part as the plastic was rounded off by a previous wrecker!!!!
    Apr 2012
    10
    Argh, still nothing. The flat I stay in has the filling loop already set up, with instructions from the property builder for fixing the water pressure. All that should need to be done is to turn the blue & black valves. Nothing happens, it doesn't even sound or feel like there is water moving inside the loop.
    Thanks for suggestions so far guys, I may be stumped on this one :-S
    dancinplumba's Avatar
    Beautiful Barlick
    7,115
    any piccies please ?
    >>>>>>>>>> I'M DANCIN, YOU ASKIN ? <<<<<<<<<<
    GSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply
    Beautiful Barlick
    7,115
    is the filling loop integral on this boiler ? if not dont understand why you are turning BLUE valve ? is this not the boiler cold main isolation valve or ch return valve ?
    loops usually have 2 black handled valves
    moogwai's Avatar
    Dec 2009
    birmingham
    1,346
    Default
    I have had 3 filling loops seize up on these boilers....if you can't get it to fill as per instructions call ideal as it should still be on warranty.
    Apr 2012
    10
    Quote Originally Posted by moogwai View Post
    It's still within warranty with the builders too, will give customer services a call tomorrow and hopefully they can send someone round to take a look.
  1. logic combi 30
    By sajman in forum Gas Safe Register Forum - Public Forum
    Last Post: 12-05-2013, 03:40 PM
  2. logic combi 30
    By sajman in forum Plumbing Forum
  3. Confusing error code with Logic Combi 35 boiler
    By Hday78 in forum Gas Safe Register Forum - Public Forum
    Last Post: 06-04-2013, 09:37 AM
  4. Confusing error code with Logic Combi 35 boiler
    By Hday78 in forum Central Heating Forum
  5. Confusing error code with Logic Combi 35 boiler
    By Hday78 in forum Plumbing Forum
    Last Post: 05-04-2013, 11:04 PM
  6. Chaffoteaux britony combi 100 error code 60
    By roberto110 in forum Central Heating Forum
    Last Post: 11-03-2013, 07:57 PM
  7. Baxi duo-tec Combi HE Range Error code 119
    By andymanila in forum Central Heating Forum
    Last Post: 08-12-2010, 08:01 PM
  8. Plumbing courses and Training
    By Varley in forum Plumbing Courses
    Last Post: 26-06-2008, 08:08 PM
logic combi 35 f1
logic combi 35 f1 error
what does f1 mean on a logic combi 30 boiler
ideal logic combi 35 f1
logic combi 35 low water pressure
