Results 1 to 15 of 26
Plumbing & Plumbers Forum - Calculating the water volume of a heating system
Discuss Calculating the water volume of a heating system in the Central Heating Forum at Plumbers Forums; Can anyone give me a specific way to calculate the water volume within a heating system? I'm trying to work out if an existing installation would benefit from an expansion ...-
14-04-2012 #1New to Plumbing Forum
- Apr 2010
- 11
Can anyone give me a specific way to calculate the water volume within a heating system? I'm trying to work out if an existing installation would benefit from an expansion vessel.
14-04-2012 #2UK Plumbersforums Trusted Advisor.
- Oct 2010
- Northampton
- 6,058
- 595
- Thanked 290 Times in 280 Posts
Re: Calculating the water volume of a heating system
my dad told me 1l for each rad will be ok plus 5 on top to back up your self !
14-04-2012 #3Plumbers Arms member
- Jun 2009
- Hampton court, Surrey
- 1,605
- Thanked 43 Times in 43 Posts
is that including pipework?
14-04-2012 #4Steady Plumbing Forum Contributor
- Nov 2010
- North East
- 235
- 14
- Thanked 28 Times in 23 Posts
Heating load wise on domestic its 6 litres per KW heat load so 18kw heat only would be 12kw x 6l = 72L in commecial its 10-12 litres per kw of heat depending on the type of output, ie underfloor or steel panel rads.
14-04-2012 #5UK Plumbersforums Trusted Advisor.
- Oct 2010
- Northampton
- 6,058
- 595
14-04-2012 #6UK Plumbersforums Trusted Advisor.
- Oct 2010
- Northampton
- 6,058
- 595
hope some one will come with the right formula
14-04-2012 #7Plumbers Arms member
- Oct 2011
- sheffield
- 224
- Thanked 10 Times in 10 Posts
14-04-2012 #8Plumbers Arms member
- Jan 2012
- Essex
- 3,202
- 80
I'm not sure that that there will be an accurate formula because the length and diameter of pipe runs would be an unknown.
If in fact you did know the true volume of a system then you could work out the size of vessel required but you would always add on a bit for luck.Proud to be 'Part P', the world is now my mollusc!
14-04-2012 #9UK Plumbersforums Trusted Advisor.
- Oct 2010
- Northampton
- 6,058
- 595
if it starts discharging just stick a 6 bar one ( from another post leaking prv)
lol
14-04-2012 #10
14-04-2012 #11Plumbers Arms member
- Oct 2011
- sheffield
- 224
14-04-2012 #12Plumbers Arms member
- Jun 2009
- 1,605
so what your basically saying is, a 3 bed house just stick in a 12 litre expansion vessel?
14-04-2012 #13Plumbers Arms member
- Oct 2011
- sheffield
- 224
14-04-2012 #14
If the existing vessel is sound and the pressure is rising excessively when heating up whack another one in? an Additional 8 litres should suit most applications?
Or do you want water content per metre info?
14-04-2012 #15Plumbers Arms member
- Oct 2011
- sheffield
- 224
think of it as not an exact science as many combi's only have 8 litre fitted,this will do most homes,but sometimes on a big house you have to fit additional expansion vessel,have seen the maths to work out vessel size,but on housing you dont have to be spot on,as combi,s are an example,but as said before on a big commercial job you would have to work it out
Problem encountered in connection of 2 water tanks with different volume
By darren72 in forum Plumbing ForumReplies: 35Last Post: 06-10-2011, 06:42 PM -
Electric shower scalding hot due to water volume fluctuations - advice needed.
By Manks in forum Plumbing ForumReplies: 11Last Post: 03-06-2011, 12:02 PM -
One for the Wet guys!!! System volume
By smillsey in forum Central Heating ForumReplies: 6Last Post: 08-03-2011, 12:12 AM -
How to increase the volume of water used in the flush?
By amateurman in forum Sanitary WareReplies: 7Last Post: 06-05-2010, 11:04 PM -
Water volume and expansion
By bonesy60 in forum Central Heating ForumReplies: 3Last Post: 21-02-2010, 09:24 PM
4Likes
Variable flow Water Pump for...
31 Minutes Ago in Plumbing Forum
