Plumbing & Plumbers Forum - munting double rad on to plastic wall panelling advice please
Discuss munting double rad on to plastic wall panelling advice please in the Central Heating Forum at Plumbers Forums; Have a 600 x 1000 double radiator to mount in my bathroom, will be mounting it on to a solid block wall, that has been clad with plasterboard, and pvc ...
    Plumbing Forum Contributor
    Jan 2012
    82
    Default munting double rad on to plastic wall panelling advice please
    Have a 600 x 1000 double radiator to mount in my bathroom, will be mounting it on to a solid block wall, that has been clad with plasterboard, and pvc marble effect wall panelling... bearing in mind the weight of the radiator empty no water....
    would i better mounting the brackets to the plasterboard/ block, i.e. cutting away the plastic panelling where the brackets mount.. rather than risk squishing the plastic pannelling cells and not having a firm mounting base for the brackets...?
    7,225
    Default Re: munting double rad on to plastic wall panelling advice please
    I think you've answered your own question
    That's the way I would go.
  3. If You Burn It, It Can Kill You.
  4. The Following User Says Thank You to SimonG For This Useful Post:
    handsomejackuk (27-03-2012)
  5. #3
    Simon F's Avatar
    Nottingham
    1,424
    or cut/drill a hole and put a block of some kind in back to the solid wall, then you will be able to tighten with no risk of damage to the plastic or plasterboard ( thats assuming the gap behind the plasterboard is not massive )
  6. The Following User Says Thank You to Simon F For This Useful Post:
  7. #4
    Jan 2012
    82
    ahh rite thanks i was thinking it may be best to cut away the plastic.... just wanted some confirmation really...the plasterboard is bonded to the block, so no cavity to put in a wooden block...
    just got to get a person with muscles to lift it up as i am a weakling.!!!!
  8. #5
    AWheating's Avatar
    WestMidlands
    5,803
    one solution could possibly be drill a hole and expanding foam the gap between the the materials so when you tighten your screws the foam will help stop the wall moving.
    btw im commercial,
    NOT.
  9. #6
    AWheating's Avatar
    WestMidlands
    5,803
    forgot to say be careful how you munt a radiator, it may bite. but it will get better looking the more you drink
    btw im commercial,
    NOT.
  10. #7
    Mike Jackson's Avatar
    Hastings
    3,895
    I'd drill the fixings and then open up the holes through the plasterboard and panelling to 15mm and use short lengths of copper tube as spacers to prevent crushing the plastic.
  1. Solar Panelling
    By Jamie Banks in forum Renewable Energy
    Last Post: 04-11-2011, 08:03 PM
  2. Solar panelling training course
    By mcnivens in forum Renewable Energy
    Last Post: 01-09-2011, 11:31 PM
  3. Replies: 4
    Last Post: 24-01-2011, 08:54 PM
  4. Free standing bath against wall advice please
    By jimmy in forum Sanitary Ware
    Last Post: 19-01-2010, 07:11 PM
  5. Bath with plastic cradle, double sided sticky !
    By ronaldbiggs in forum Sanitary Ware
    Last Post: 02-08-2009, 08:39 AM
