Plumbing & Plumbers Forum - Potterton Netaheat Profile 80 Cut Out Problem
Discuss Potterton Netaheat Profile 80 Cut Out Problem in the Central Heating Forum at Plumbers Forums; This week Potterton Netaheat Profile 80 tripped out and I used the reset button to try and get it going again, but ... it didn't restart until I turned the ...-
24-03-2012 #1New to Plumbing Forum
- Dec 2011
- 6
This week Potterton Netaheat Profile 80 tripped out and I used the reset button to try and get it going again, but ... it didn't restart until I turned the boiler thermostat down to 0.
Now, if the boiler is cold it will only restart with the boiler thermostat set to 0. As it warms up, the boiler thermostat can be turned higher before it cuts out (this is backwards!). If I leave it running it eventually trips out and I have to use the reset button to get it going again.
Any ideas anyone? Is the boiler thermostat faulty?
Thank you!
24-03-2012 #2Steady Plumbing Forum Contributor
- Jun 2011
- 106
- Thanked 5 Times in 5 Posts
Re: Potterton Netaheat Profile 80 Cut Out Problem
sounds like its over heating could be a number of faults, u will need a gsr engineer
24-03-2012 #3Plumbers Arms member
- May 2009
- 7,302
- 218
- Thanked 683 Times in 604 Posts
Does sound like the boiler thermostat is sticking a kaput ,the reset is down to the boiler over heating,get thermostat replaced
imho
25-03-2012 #4Banned
- Mar 2012
- 11
- Thanked 2 Times in 2 Posts
Hi
I agree with the first guy as the boiler may well be doig what it is designed to do.
Normal questions would be:
Are the flow and returned getting hot away from the boiler i.e. radiators as your pump may be stuck or u/s.
It may be seized zone valves(check action), a lack of water (check tanks and radiators) or a blockage (requires corrosion removal!).
If your pumps going (check spinning and not just noisy) and you have full circulation
then it may be your stat. Most times the stat will be doing it's job so I'd still get someone in to do ther basic checks.
Phil
25-03-2012 #5New to Plumbing Forum
- Dec 2011
- 6
Thanks Everyone
PhilJones, I find it hard to believe the boiler is doing what it is designed to do when the stat is working backwards (turn it up it goes off, turn it down it comes on?!).
The rads are getting hot and we're getting loads of hot water from the cylinder. I'm not 100% sure (need to lift floorboards to check), but I think it is a mixed (gravity hw, pumped heating) system. The pump may be on it's way out as well, so must take a look ...
Just trying to nurse along an old system, because we're hoping to extend soon ;-)
Potterton Netaheat Profile 80 Does Not Light
By skobulike in forum Central Heating ForumReplies: 12Last Post: 18-05-2012, 01:03 PM -
Potterton Netaheat Profile 80e - boiler thermal cuts out...
By Roblion in forum Central Heating ForumReplies: 6Last Post: 24-01-2012, 09:52 AM -
Wiring in room stat to my Potterton Netaheat Profile 40e
By Wintersun in forum Central Heating ForumReplies: 30Last Post: 24-12-2011, 04:02 PM -
Potterton profile, problem
By RTPS in forum Gas Safe Register Forum - Public ForumReplies: 7Last Post: 06-01-2010, 06:26 PM
1Likes
ecv
6 Minutes Ago in Gas Safe Register Forum - Public Forum
