Results 1 to 12 of 12
Plumbing & Plumbers Forum - Glow worm 24 cxi
Glow worm 24 cxi
Discuss Glow worm 24 cxi in the Central Heating Forum at Plumbers Forums; hi all any one where i can get the technical drawings for the above boiler, i need to find the part name and number, i know the part i want ...
    MZR
    MZR is offline
    MZR's Avatar
    Dec 2011
    158
    Default Glow worm 24 cxi
    hi all
    any one where i can get the technical drawings for the above boiler, i need to find the part name and number, i know the part i want :
    from below it connects to the cold inlet and inside it connects to the flow switch just need to know which part it is so i can order one as its leaking between the this part and the flow switch.
    all the manual says its the RH hydro block ????
  2. www.blockeddrainsbirmingham.co.uk
    http://mzrplumbing.blogspot.co.uk/
    www.emergency-plumberbirmingham.co.uk
    http://www.blockeddrainsbirmingham.co.uk/blog/wp/
    Discussion contents reflect the views of individual participants only. MZR Plumbing & Drainage and its owner organizations bear no responsibility for accuracy of participant comments and will bear no legal liability for discussion results.
  3. #2
    Sep 2010
    Cardiff
    492
    Default Re: Glow worm 24 cxi
    Glowworm-ultracom-2-24-cxi-installation-manual
    Try this
    MZR
    MZR is offline
    MZR's Avatar
    Dec 2011
    158
    its not an ultracom the GC number is : GC 47-047-23
    Sep 2010
    Cardiff
    492
    How about this one Glowworm-24-Cxi-installation-manual
    Same Gas Number
    MZR
    MZR is offline
    MZR's Avatar
    Dec 2011
    158
    yeah i have that manual, the part i need is page 45 fig 14.7 its the part under the retaining clip attached to the flow sensor ??? but no name or part number for it
    Sep 2010
    Cardiff
    492
    Oh I see.. The only thing I can suggest is to go to parts centre and ask them to put it up on there screen. The will have a part number for every thing on that boiler. Book will only give you certain info. Good luck!
    Tavistock. Devon
    1,821
    Hi MZR thats what it is calld Right hand Hydro-Block common fault, expensive part, around £200.00.
    MZR
    MZR is offline
    MZR's Avatar
    Dec 2011
    158
    ok thanks any links to where i can buy on the net ???? do the parts not break down into individual parts ?
    Tavistock. Devon
    1,821
    All you will get is the main block, you have to swap over all the other bits, quite a costly peice of plastic ! Right Hand Block around the same price
    Roger Welton's Avatar
    Dec 2011
    Somerset
    1,824
    All glow worm parts seem to be a little on the expensive side to me.
    MZR
    MZR is offline
    MZR's Avatar
    Dec 2011
    158
    well its for an insurance company so costs are not mine or the customers so i dont mind how much its just finding a merchant to stock them ASAP
  13. #12
    Tavistock. Devon
    1,821
    Any parts supplyers should have them in stock common fault You should have a Parts Center near you! even most of Plumb Centers now doing parts ! Note that you will have to be GSR to work on Boilers ! especially as its for an insurance Co.
  1. Glow-worm 100 ff
    By Darkcloud in forum Gas Safe Register Forum - Public Forum
    Last Post: 03-02-2012, 09:55 AM
  2. glow worm 38 cxi
    By chelsea in forum Gas Safe Register Forum - Public Forum
    Last Post: 22-11-2011, 06:05 PM
  3. glow worm
    By oscar 087 in forum Plumbing Forum
    Last Post: 27-05-2011, 11:00 AM
  4. Glow worm self cut out
    By CozyDog in forum Gas Safe Register Forum - Public Forum
    Last Post: 31-03-2010, 10:58 PM
glow worm 24cxi hydroblock
glow worm 24cxi installation manual
glow worm 24cxi leaking
glow worm 24cxi manual
glowworm cxi f4
glow worm manual 24cxi
24 cxi glow worm water two hot
