Plumbing & Plumbers Forum - Leaking expansion tank valve
Discuss Leaking expansion tank valve in the Central Heating Forum at Plumbers Forums; Hi all, Right I checked my expansion tank pressure today and when I pressed the valve only a small amount of air came out. I topped it up to about ...
    Jan 2012
    Default Leaking expansion tank valve
    Hi all,
    Right I checked my expansion tank pressure today and when I pressed the valve only a small amount of air came out. I topped it up to about .7 bar, but I believe the valve is leaking. Does this mean I need a new tank, or is the valve replacable?
    Many thanks
    east london
    6,666
    Default Re: Leaking expansion tank valve
    replace able if you can get it out ive found best place for replacement is local tyre shop you need a special key to remove it
    cdodds2004's Avatar
    626
    its quite easy to do IF the valve is easy to get to, some are some arnt lol
    For a premier service in Telford and surrounding areas
    boiler,installation,servicing,landlords Certs
    breakdowns,plumbing and gas work
    www.firstcallgasandheating.co.uk
    Roger Welton's Avatar
    Dec 2011
    Somerset
    1,744
    Where did you get the tool from? and the replacement valves, does it remove the hole valve or just the core?
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,971
    halfords should have the tool
  6. The Following User Says Thank You to steveb For This Useful Post:
    Roger Welton (11-03-2012)
    johnnyplumb's Avatar
    Aug 2010
    Glesca
    773
    Quote Originally Posted by Roger Welton View Post
    Ebay, I got key and 4 valve cores for £2
    CONFUCIUS SAY- man with hole in trouser pocket, feel cocky all day,
    man with 2 holes in trouser pocket, no feel too cocky.
    32 years as a jazz drummer & still dont know ma erse fae ma elbow
  8. The Following User Says Thank You to johnnyplumb For This Useful Post:
  9. #7
    Plumbers Arms member MattWeth's Avatar
    Cheshire
    453
    Standard pushbike parts - any bike shop will have the necessary stuff. Some of the old fashioned plunger type tyre pressure gauges have the removal tool built in.
  1. Replies: 4
    Last Post: 28-11-2011, 12:04 AM
  2. Replies: 8
    Last Post: 03-11-2011, 01:25 AM
  3. expansion tank
    By heggie in forum Plumbing Forum
    Last Post: 04-04-2011, 07:47 PM
  4. ch expansion tank
    By paddyo in forum Central Heating Forum
    Last Post: 05-01-2010, 10:19 PM
  5. ch expansion tank
    By paddyo in forum Plumbing Forum
central heating expansion tank leaking
expansion tank valve leaking
plumbing overflow tank valve
replace expansion cylinder valve
central heating expansion tank dripping
leaky expansion tank valve
