Results 1 to 10 of 10
Plumbing & Plumbers Forum - Underfloor Heating
Underfloor Heating
Discuss Underfloor Heating in the Central Heating Forum at Plumbers Forums; Hi, I am building my own house at the moment and about to install the plumbing. I was thinking of putting in some underfloor Heating. The floor hasn't been screeded ...-
08-03-2012 #1New to Plumbing Forum
- Mar 2012
- 3
Underfloor Heating
Hi, I am building my own house at the moment and about to install the plumbing. I was thinking of putting in some underfloor Heating. The floor hasn't been screeded yet and i have about 60/65mm of screed to go on.
Can i add underfloor heating to my floor with that amount of covering? Also can you use Poly pipe for the floor heating system and what do you use to divide the pipes up and lift them off the floor or do you lay yhem on top of the concrete?
Any help as i have no idea about this subject matter?
Thanks,
Ian C
08-03-2012 #2Plumbers Arms member
- Feb 2011
- 7,504
- 287
- Thanked 714 Times in 704 Posts
Re: Underfloor Heating
Have a look at the John Guest Speedfit website for the underfloor heating. Lots of info on there.
Fly Me To The Moon And Let Me Play Among The Stars...............
08-03-2012 #3New to Plumbing Forum
- Mar 2012
- 3
thanks! Will take a look.
09-03-2012 #4Plumbers Arms member
- Dec 2009
- birmingham
- 1,142
- 128
- Thanked 71 Times in 67 Posts
Hi Mate,
just laid the pipework in my own extension and it went down like this
1. 120mm concrete slab
2. 100mm celotex insulation
3. u/f heating pipework stapled to the insulation (my mate did this in a pattern so the pipework was run in at 100mm centres)
4. 60mm liquid screed. this stuff is way better than normal screed...pumped in an hour (30m2)....gone off in 3/4 days and is self levelling whereas it takes normal screed upto 3 months to dry out properly
10-03-2012 #5Plumbers Arms member
- Oct 2009
- 266
- 3
- Thanked 6 Times in 6 Posts
wundafloor is good for underfloor heating used it a few times good prices to done one back last year with myson that was not bad either.
10-03-2012 #6UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
"nothing is impossible"
20-11-2012 #7New to Plumbing Forum
- Nov 2012
I Have used Wunda several times, their 16mm pipe is identical in appearance to uponors .but a whole lot cheaper and i can call in to their offices and pick it up.
21-11-2012 #8Plumbing Forum Contributor
- Dec 2011
- 41
- Thanked 2 Times in 2 Posts
Will defo need insulation underneath pipework, kinspan/sellertex etc. Also good idea to insulate between screeded floor and walls the screed would be in contact with, this would help prevent heat bleeding out the floor into the fabric of the building. Pipe sizing and pipe spacing would be worked out by a heat loss calc.
21-11-2012 #9UK Plumbersforums Trusted Advisor.
- Jun 2010
- Northern Ireland
- 4,873
- 76
- Thanked 447 Times in 434 Posts
First you need to ascertain if you have enough floor covering at this stage
You need 100 mm celotex insulation
Then screed whether it be liquid or sand cement
But you will also need correct ceiling height to pass building controlGSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply.
21-11-2012 #10UK Plumbersforums Trusted Advisor.
- east london
- 6,749
- 9
- Thanked 387 Times in 375 Posts
polypipe do a thin system which might fit in the limited space you have uses 12mm pipe in a preformed backing ive only used it under floating floor so not sure if it wwill work under screed have a look at the polypipe web site
greetings from Underfloor Heating Now
By underfloorheati in forum New Member IntroductionsReplies: 5Last Post: 08-03-2012, 10:48 PM -
Underfloor heating
By lenny in forum Central Heating ForumReplies: 9Last Post: 22-08-2011, 05:22 PM -
Underfloor heating
By gavla in forum Bathrooms, Showers and WetroomsReplies: 3Last Post: 29-11-2010, 05:56 PM -
Underfloor heating.
By Kip in forum Central Heating ForumReplies: 9Last Post: 31-12-2009, 10:59 PM -
underfloor heating
By Danny boy in forum Plumbing ForumReplies: 2Last Post: 15-12-2008, 07:50 AM
How???????????
6 Minutes Ago in General Off-Topic Chat
