Results 1 to 6 of 6
Plumbing & Plumbers Forum - Leak detection in central heating systems
Discuss Leak detection in central heating systems in the Central Heating Forum at Plumbers Forums; I wonder if any forum members have experience of modern leak detection systems as I would be interested in their views and experiences. The query is triggered by a leak ...-
22-05-2009 #1NimrodGuest
The query is triggered by a leak on a pressurised domestic central heating system. It drops about half-a-bar in 24 hours. The pipes serving the downstairs radiators are embedded in a concrete floor.
As I can find no water damage to ceilings I assume the leaks in the solid floor.
The systems been dosed with sealant but it doesn't seem to have had much effect.
B
22-05-2009 #2Plumbers Arms member
- May 2009
- 7,302
- 218
- Thanked 683 Times in 604 Posts
Re: Leak detection in central heating systems
If you are loosing .5 a bar in 24 hrs leak sealer will probably not work I am afraid, pipework will have to be re-run surface or leak detected in floor and repaired
It is worth mentioning that if leak sealer in used for a small leak, say a drop over 3 or more days, then on a pressurized system, to give it a better chance of working the pressure should be dropped to .5 bar and heating thermostat lowered to provide warm radiators only for a few days needless to say some combi boilers will not work at this pressure
22-05-2009 #3Plumbers Arms member
- Jan 2009
- 172
- Thanked 4 Times in 3 Posts
What leak sealer did you use?
22-05-2009 #4Plumbers Arms member
- May 2009
- 7,302
- 218
I use fernox
22-05-2009 #5Super Plumbing Forum Contributor
- Feb 2009
- Liverpool
- 1,972
Hmm
What principle do leak detectors work on?
If it sets on a temperature rise accompanied by exposure to air, then pipework enclosed in concrete is not going to have much air circulating to set it off, I would not have thought.
Its like Radweld that has been used in car radiators for years. Reports say success only patchy. But hey the chance you may have to dig up a floor ain't funny.
22-05-2009 #6SUPER MODERATOR
- Jan 2009
- sherrif county
- 9,252
- 242
- Thanked 541 Times in 504 Posts
as its summer now, so im told. why not try an air test pipe to pipe then re run the leaking section.
Hot water is lukewarm but Central heating working OK.
By fplumber in forum Plumbing ForumReplies: 2Last Post: 14-05-2009, 10:44 PM -
Central Heating comes on when Hot Water Tap is Opened
By tictactile in forum Plumbing ForumReplies: 4Last Post: 12-05-2009, 02:41 AM -
cannot have central heating on without hot water also being on
By legaraal in forum Central Heating ForumReplies: 1Last Post: 27-04-2009, 05:32 PM -
hot water not heating but central heating working???
By bigd111 in forum Plumbing ForumReplies: 7Last Post: 09-04-2009, 03:58 PM
Holidays
3 Minutes Ago in General Off-Topic Chat
