Plumbing & Plumbers Forum - BIASI Boiler stopped working during radiator balancing - now not working
Discuss BIASI Boiler stopped working during radiator balancing - now not working in the Central Heating Forum at Plumbers Forums; I stupidly decided to balance my radiators this morning as the ones furthest away from the boiler were cool. I followed the instructions found on the internet and everything seemed ...-
05-02-2012 #1New to Plumbing Forum
- Feb 2012
I stupidly decided to balance my radiators this morning as the ones furthest away from the boiler were cool. I followed the instructions found on the internet and everything seemed to be going well until I bled the bathroom radiator, topped up the filler loop a little and then turned down the CH knob on the boiler. It turned off and after a few seconds the normal operation light started flashing quickly (usully it is 1x green flash per second) at the rate of 4x flases per second.
The temp. guage looked a bit higher than usual so I turned the boiler off at the switched spur and let it cool down. I opened all the valves on each of the first floor rads (in case I had caused the boiler to overheat through restricting flow arounf the circuit) and after 20 minutes turned the power back onto the boiler. The normal operation light flashed as usual at one flash per second as I called for heat with the switch. It made various clicking and gurgling noises before it turned off and the green light started flasing at the faster rate again. I repeated this operation a few times but to no avail. It is freezing outside and now inside !.
I opened the PCB panel and checked the fuse to the fan/pump and it looked ok so popped it back and tried to restart the boiler. The same thing again but I noticed this time that when there was a click and change to the flashing light sequence a green led in one of three small plastic housings on the PCB flashed as well.
The service lights are not flashing other than the normal operation light.
Can anyone offer any advice. I have taken a phot of the circuit board and can post if required.
Thanks in advance.
05-02-2012 #2
Re: BIASI Boiler stopped working during radiator balancing - now not working
Take a picture of the valves under the boiler if you can, was it banging and clattering as it went off?
The Following User Says Thank You to Nostrum For This Useful Post:
5thblyscouts (05-02-2012)
05-02-2012 #3New to Plumbing Forum
- Feb 2012
Thanks for responding. No it just shut down and wouldn't restart.
By sheerc coincident a friend called round who has a mate who os a Gas Safe Engineer and he rang him up,
He asked me to take off the condensation pipe and try and start the boiler. I couldn't get the pipe off as it was mortared into the wall and wouldn't flex enough but wa letting a couple of drips of water out. It wouldn't start the first two times and then I accidently pressed the pressure releif valve button and water spurted out. It then started and has ran for the last hour. I will get someone out to look at it tomorrow to be on the safe side.
Thanks once again for your assistance.
micro genus type c boiler stopped working,no powerreaching system?
By tobiasm in forum Central Heating ForumReplies: 2Last Post: 21-01-2012, 05:18 PM -
Outside tap stopped working
By Richard Ford in forum Valves & TapsReplies: 5Last Post: 03-08-2011, 11:12 AM -
Heating stopped working
By Harty084 in forum Central Heating ForumReplies: 20Last Post: 25-11-2010, 08:32 PM -
Siemens handheld receiver and sender has stopped working with Worcester combi boiler
By Mrs C York in forum Central Heating ForumReplies: 3Last Post: 06-05-2010, 08:19 PM -
Central heating pump stopped working
By WDeranged in forum Central Heating ForumReplies: 1Last Post: 17-02-2010, 05:31 AM
stanley tool bag
3 Minutes Ago in Plumbing Tools
