Any suggestion sof what to start looking at trying will very appreciated.
A couple of months ago we moved into our Bungalow, it's had a small extension on the back of the kitchen with a Rad added t-ing off from the bedrrom rad (the last one on the circuit.) The 'extra' rad (in the extension) has never got hot but all the other 6 do. I've changed both valves on the rad that doesn;t work and the TRV on the rad it's Teed from as this was always cold.
I can;t be sure but I think at some point the Valves on the rad in the bedroom have been reversed as the return pipework is a hell of a lott hotter than the flow (with the TRV on). Seeing as the TRV is bi-directional I didn;t see it as a problem. The pipework leading away from the bedromm rad going to the extension rad gets cold within 2 or 3 feet of the beddroom rad so there's is only cool'ed water going to the extension rad. I've bled the system, there's no air, bled the pump in the ol Combi, fine.. Could it be that because it's an old combi (about 12 years old) that the pump isn't strong enough to feed the extra rad? Could it be they've t'eed off the wrong pipes in the bedroom (didn;t think that would matter though as only regular wheel head and lock shield on extension rad so water will flow through both either way).
Any suggestion greatly recieved.
Cheers Tosh
