Results 1 to 12 of 13
Plumbing & Plumbers Forum - Logic combi 24 hot water problem
Like Tree2Likes
Discuss Logic combi 24 hot water problem at UK Plumbers Forums; Hi,I had a new logic+combi24 boiler fitted early this year. The heating function is working perfect, but I have trouble with the hot water system. Only one hot tap in ...
    Dec 2011
    Default Logic combi 24 hot water problem
    Hi,I had a new logic+combi24 boiler fitted early this year. The heating function is working perfect, but I have trouble with the hot water system. Only one hot tap in the house is giving hot water, the other ones at best is only tepid more often than not completely cold. The one that is working, in the downstairs cloakroom, is giving very hot water. Any observations on this please?
    Thankyou, Keith
    Simon F's Avatar
    Nottingham
    2,211
    Default Re: Logic combi 24 hot water problem
    suggests an issue with pressure or flow rate
  3. The Following User Says Thank You to Simon F For This Useful Post:
    diamondgas's Avatar
    Newcastle Upon tyne
    7,001
    to the forum Keith
    How good is your cold water flow would you say? Can you run a tap downstairs and one upstairs? Is the tap in question that is tepid thermostatic do you know? And is the tap in question the bath tap? Your boiler has a 5yr warranty, by-the-way so the manufacturers are your first port of call should you want someone out!
    However if you can answer the above it may help us more help you
  5. The Following User Says Thank You to diamondgas For This Useful Post:
  6. #4
    Dec 2011
    Thanks very much for your answer. The water flow is fine, a tap upstairs and one downstairs at the same time flowing strong. There is no thermostates on any taps, just the shower. All the taps are tepid except for the wash basin in the downstairs cloakroom, that is the only one that gets really hot. The boiler is upstairs in what was the airing cupboard.
    Keith
  7. #5
    Mar 2010
    gloucestershire
    60
    What about your shower? Does that get hot?
  8. The Following User Says Thank You to benny_headland For This Useful Post:
  9. #6
    Dec 2011
    Thanks for your reply. A tap upstairs and a tap downstairs running strong at the same time. No thermostates on any taps other than the shower. All taps are tepid or cold other than the wash basin in the downstairs cloakroom, that is the only one that gets hot.The boiler is upstairs in what used to be the airing cupboard.
    Keith.
  10. #7
    Dec 2011
    No, the shower does not get hot.
    Keith.
  11. #8
    diamondgas's Avatar
    Newcastle Upon tyne
    7,001
    I had a feeling you might come back with something like this... It could be as simple as the fact its winter alas! 24kW boiler is limited in its hot water capabilities, great in the summer but perfomance weakens in the winter months!
    Easiest fix is to restrict the flow of water to the taps that are tepid! Turn them back a bit until the water gets to the temp you desire!
    You can also check the boiler performance if you posses a stop watch, thermometer and some form of water gauge, milk bottle, measuring jug, that sort of thing?
  12. The Following User Says Thank You to diamondgas For This Useful Post:
  13. #9
    Mar 2010
    gloucestershire
    60
    Could have a cold and hot crossed somwhere causing it to mix ?!?!
  14. The Following User Says Thank You to benny_headland For This Useful Post:
  15. #10
    Mar 2010
    gloucestershire
    60
    Yes I get that on my boiler actually have to turn the shower valve all the way round in the winter to get any good heat out of it ! Crappy 24 kw gloworm!!!
    diamondgas likes this.
  16. The Following User Says Thank You to benny_headland For This Useful Post:
  17. #11
    Jan 2011
    Charing
    1,058
    Sounds like a DHW heat exchanger blockage or scale problem, Get the manufacture out!
    Need an Alpha boiler repair or a service? If you're in Kent then give Alpha man a call to arrange a visit. Telephone 01233 712994, Steve, of Greenside Heating Services, GSR number 296.
    Sorry, no free technical advise given to the public either over the Internet or telephone.
    I will only visit if you're in KENT
    (I'm not Alpha nor work for them, just an Independant engineer.)
    Steve
  18. #12
    Mar 2012
    6,912
    Didn't fancy registering then?
  1. Ideal logic + combi boiler problem.
    By Sfc in forum Central Heating Forum
    Last Post: 31-12-2016, 05:55 PM
  2. Firebird Combi Hot Water Problem
    By Mole2005 in forum Oil and Solid Fuel Forum
    Last Post: 22-09-2016, 08:49 AM
  3. hello
    By uug197h in forum New Member Introductions
    Last Post: 15-10-2015, 08:19 AM
  4. ideal logic 30 combi water pressure loss
    By RoBBster in forum Gas Safe Register Forum - Public Forum
    Last Post: 02-03-2013, 06:27 PM
  5. Ferroli f30 combi hot water problem!!!
    By mad_footie_lad in forum Central Heating Forum
    Last Post: 03-01-2012, 11:20 PM
  6. Hot Water problem - Worcester 240 combi
    By Colin68 in forum Central Heating Forum
    Last Post: 15-09-2011, 12:25 AM
  7. Britony Combi Hot Water Problem
    By rking100 in forum Plumbing Forum
    Last Post: 19-08-2010, 09:10 PM
  8. combi hot water problem
    By hazy p in forum Plumbing Forum
    Last Post: 06-07-2010, 09:26 PM
ideal logic combi 24 no hot water
ideal logic no hot water
logic combi 30 no hot water
ideal logic combi 24 hot water problem
