Plumbing & Plumbers Forum - vitodens 100-w 35kw pump settings
Discuss vitodens 100-w 35kw pump settings in the Central Heating Forum at Plumbers Forums; Hi, hoping some one has experience with veissmann set up, it says comes with pump setting on '1' and you can change it to '2' through messing about with the ...-
17-12-2011 #1Plumbing Forum Contributor
- Oct 2011
- 47
- Thanked 10 Times in 10 Posts
Hi, hoping some one has experience with veissmann set up, it says comes with pump setting on '1' and you can change it to '2' through messing about with the control dials not actualy a leaver on the pump, is this setting just speed? Is two faster? How do I determine what setting I need it on?
Thanks its for the boiler in my home not a custard
17-12-2011 #2Top Plumbing Forum Contributor
- Jan 2011
- Charing
- 602
- 7
- Thanked 55 Times in 54 Posts
Re: vitodens 100-w 35kw pump settings
Wont it be the MI?
Got a Alpha boiler with a problem, then you need help from Alpha man! Covering all areas in Kent and stock carried on the Van.
Steve
17-12-2011 #3Plumbing Forum Contributor
- Oct 2011
- 47
The MI tells you how to change the setting but not what the difference is or why you would change it that's why I don't know what to have it on
17-12-2011 #4Plumbers Arms member
- May 2010
- Hythe, Kent
- 226
- 3
- Thanked 13 Times in 12 Posts
Viessmann instructions aren't all that are they! We did the 100 course, some sort of binary arrangement like you say with the knobs, I think you put it in service by putting both knobs at 12 o'clock until it shows "SERV" then on from there..... Does it all work on the speed it's on at mo?
18-12-2011 #5Plumbing Forum Contributor
- Oct 2011
- 47
Yes it all works but just wanted to know what the difference is and if it would work out more efficient or anything
CH settings
By tfc475 in forum Central Heating ForumReplies: 2Last Post: 14-12-2011, 09:19 PM -
Viessman Vitodens 200 35kW
By monahann in forum Central Heating ForumReplies: 2Last Post: 08-04-2011, 05:56 PM -
new viessmann Vitodens 100w 35kw hot water
By giarc00007 in forum Plumbing ForumReplies: 3Last Post: 25-10-2010, 06:40 AM
Really remote heating controls -...
20 Minutes Ago in Central Heating Forum
