Results 1 to 15 of 17
Plumbing & Plumbers Forum - condensing boiler service schedule?
Discuss condensing boiler service schedule? in the Central Heating Forum at Plumbers Forums; I just had a Gas Safe plumber "service" my Gloworm,I think the boiler knew more about him that he did about it.What parts should be inspected in a newish (12 ...-
16-12-2011 #1New to Plumbing Forum
- Dec 2011
- 7
I just had a Gas Safe plumber "service" my Gloworm,I think the boiler knew more about him that he did about it.What parts should be inspected in a newish (12 month) condensing boiler?
16-12-2011 #2Plumbers Arms member
- Jun 2010
- 698
- 11
- Thanked 107 Times in 106 Posts
Re: condensing boiler service schedule?
Your boiler does as any other boiler require servicing anually. Alot of visual inspectings, water leaks,flue, case integrety,burner seals,condensate drain/trap,safety blow off termination, also gas pressures/rate. The boiler should also have a flue gas analysist done to make sure it's burning correctley. The engineer will also check the safety devices.
A good thorough Gas Safe Engineer does know what they're doing & can make it look easy, he may also spot things about the boiler that are not just part of the mandartory safety checks. On your behalf, it's in your interest to have the boiler serviced yearly,as if you don't you'll find your extended warranty void if not & even worse if left the burner gaskets will leak & melt lots of critical/expensive parts.
16-12-2011 #3New to Plumbing Forum
- Dec 2011
- 7
He said the flue was within normal limits so didn't need any other checks done.Still cost me £50 cash.Does this sound about right?Thanks for the previous reply.
16-12-2011 #4UK Plumbersforums Trusted Advisor.
- Sep 2010
- Livingston
- 2,270
- 173
- Thanked 267 Times in 237 Posts
He should have at least tested the gas rate (how much gas it is burning), the safety devices and carried out a visual inspection. I assume he left paperwork and filled in the benchmark box in the manual? (A bit like the logbook for a car)
If you cant fix it with a hammer, you've got an electrical problem..
Heating Engineer in Livingston
Cha togar m' fhearg gun dìoladh
GSR? want gas safety or boiler repair advice? we will check out that your genuine via the gas safe website,so please don't be offended when we ask for your details diyers, potchers, odd job people and have a go heroes need not apply
16-12-2011 #5UK Plumbersforums Trusted Advisor.
- Oct 2010
- Glasgow, Scotland
- 4,696
- 324
- Thanked 260 Times in 254 Posts
you were robbed
£50 is finePlumber down under, not working as a plumber
16-12-2011 #6New to Plumbing Forum
- Dec 2011
- 7
16-12-2011 #7Plumbers Arms member
- Jun 2010
- 698
- 11
I charge more, As long as he's done the neccessary checks, all's good. Strip it & fit New burner seals on year 3 or 4.
16-12-2011 #8
£50 is about right, probably a touch on the low side.
Flue gas analysis equipment to test modern condensing boilers is extremely expensive to buy & expensive again to have calibrated each year
16-12-2011 #9UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
- Thanked 676 Times in 610 Posts
Wish I could get my van serviced for £50 a year. £50 for a year's heating seems a bargain to me!
16-12-2011 #10Plumbers Arms member
- Nov 2010
- West Sussex
- 598
- 12
- Thanked 30 Times in 29 Posts
On the flip side I went to service a 12 month old Glowarm Ultracom HXI today and found loads of condensation around the fan, advised the customer to contact Glowarm for a under guarantee visit, no charge made by me. Should have been £66 inc vat .
safe-gas-installer.co.uk
16-12-2011 #11Plumbers Arms member
- Oct 2009
- 758
- 181
- Thanked 33 Times in 32 Posts
I service boilers and many engineers may or may not back me up but a few customers expects the absolute world. I do what is needed as per what the customer wants/pays for. if you got your car serviced what would you expect (every panel striped, engined dropped out, g/box out, drained etc etc, doubt it) If the bp was ok, gr was ok, nice and clean, flue combustion all good, clearences, ventalation etc etc , id be well happy with 50 quid
16-12-2011 #12New to Plumbing Forum
- Dec 2011
- 7
Oh,I am happy with it. I did not expect any work needing doing after 12 months, the engineer was a pleasant chap as well, and I needed a signature to show a 12 month service had been done in the log, for when I sell (if the boiler lasts that long).I was just surprised there was so little to do :just a look at the top of the boiler and a gadget poked at it.Thanks all of you for responding to this thread.
18-12-2011 #13Plumbers Arms member
- Nov 2010
- Tavistock. Devon
- 1,794
- 38
- Thanked 173 Times in 160 Posts
Well done Kev , another gas engineer that tells how it is, Ive done the same , we will never be Millionaires.
19-12-2011 #14New to Plumbing Forum
- Dec 2011
- 7
"Well done Kev , another gas engineer that tells how it is, Ive done the same , we will never be Millionaires.
Not for want of trying, sometimes! A few years ago we had an extension built.My son overheard the builder telling the plumber to "find some snags so we can charge some extras, as it is going too smoothly and we will finish within the quote" or words to that effect.When we sacked the plumber after he hit a non-existant snag, he left a slow leak under the floor which needed remedial work a year later, costing a lot.This is all documented as we considered suing, but the builder had gone bust by then, and it was covered by our insurance anyway.I could supply the names if anyone wanted them, but would be reluctant to do so as the plumber has done some good work for us in the past.He was influenced by a more experienced, over-bearing builder. As I say, it's the 99% who tarnish the reputations of the 1%...Last edited by alibongo; 19-12-2011 at 07:43 AM.
19-12-2011 #15UK Plumbersforums Trusted Advisor.
- Sep 2010
- Livingston
- 2,270
- 173
Schedule of Rates
By andrewstokes87 in forum Plumbing ForumReplies: 16Last Post: 20-09-2011, 12:14 AM -
Schedule of rates
By andrewstokes87 in forum Plumbing ForumReplies: 13Last Post: 19-09-2011, 08:52 PM -
Condensing Boiler
By steven wheaton in forum Central Heating ForumReplies: 3Last Post: 04-10-2009, 02:59 PM -
Reliable condensing boiler
By discostewart in forum Central Heating ForumReplies: 14Last Post: 29-12-2008, 10:06 AM
analyser readings
6 Minutes Ago in Oil and Solid Fuel Forum
