Results 1 to 1 of 1
Plumbing & Plumbers Forum - Worcester Bosch 230: water, rads too hot!!
Discuss Worcester Bosch 230: water, rads too hot!! in the Central Heating Forum at Plumbers Forums; Can someone help please? Water coming out of boiler too hot. Turned down thermostat on front of the boiler to its lowest setting, but no use! Also the radiators are ...-
19-04-2009 #1Phoenix99Guest
Can someone help please? Water coming out of boiler too hot. Turned down thermostat on front of the boiler to its lowest setting, but no use! Also the radiators are too hot as well. Again, turning down the TMV's made no difference! Had a plumber call and he said there was nothing wrong
Lastly, there is a dripping sound which seems to be coming from the top of the boiler
In the last two years the boiler has had a new pump, diaphragm, fan and circuit board.
Help please!
Worcester 240 Combi no hot water
By raze1000 in forum Central Heating ForumReplies: 7Last Post: 21-01-2013, 11:15 AM -
Bungalow with requirement for instant hot water and more water pressure in bathrooms
By David Salter in forum Bathrooms, Showers and WetroomsReplies: 3Last Post: 06-10-2009, 11:56 PM -
Hwlo with wold water tank overflowing
By philwilliams in forum Plumbing ForumReplies: 2Last Post: 13-04-2009, 08:57 PM -
Hot taps run cold - not the boiler, I reckon...
By plumb-line in forum Plumbing ForumReplies: 4Last Post: 30-03-2009, 09:21 AM -
Brown hot water
By Leeky in forum Central Heating ForumReplies: 10Last Post: 14-12-2008, 02:50 PM
heat pumps course
6 Minutes Ago in Renewable Energy
