Plumbing & Plumbers Forum - Central Heating pump replacement
Discuss Central Heating pump replacement in the Central Heating Forum at Plumbers Forums; Help! Just bought a bungalow, ( a repossession) that has been empty for over a year so you can imagine what last winter did to the heating system. A sign ...-
06-11-2011 #1New to Plumbing Forum
- Nov 2011
- 3
Help!
Just bought a bungalow, ( a repossession) that has been empty for over a year so you can imagine what last winter did to the heating system. A sign on the boiler, an Alpha 240E said the system had been drained but it must have been after the big freeze. Checked the pipework in the roof and repaired a number of blown joints. Tried to fill the system but then realised the pump was leaking. On closer examination a 50mm x 60mm chunk of cast has been blown out of the back of the pump by the frost. It appears to be a specific pump for this boiler and at around the £100 mark I don't want to shell out my hard earned only to find the boiler is shot so my questions are, a) can I test the boiler for water tightness without the pump in situ or b) is there anywhere i could just buy the pump body as the pump has 1" bsp fittings and an air separator?
06-11-2011 #2UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Just buy a cheap pump from screw fiddle.
What pump is in there ate the mo Grundfos 15-50??
"nothing is impossible"
06-11-2011 #3New to Plumbing Forum
- Nov 2011
- 3
Re: Central Heating pump replacement
Pump is Grundfos 15-60 but with 1"bsp fittings as opposed to the standard 1 1/2" ones. Also it has an air separator on the housing.
06-11-2011 #4UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Sorry just realised this is an internal pump
You might as well just buy a new boiler
And you shouldn't be touching this pump. Everything inside the boiler is GSR only"nothing is impossible"
04-12-2011 #5New to Plumbing Forum
- Nov 2011
- 3
Just an update. Cobbled up some plugs to replace the pump. Pressurized the system and all watertight. Bought a pre-used pump for £35. Got the system checked and serviced by a GSR guy and heating up and running for less than £140. Much cheaper than a new boiler. A great big thanks for nothing to SimonJohns for his unhelpful advice and Prima Donna attitude. Don't bother replying to this post cos I won't be back.
Central heating pump
By lenny in forum Central Heating ForumReplies: 17Last Post: 31-08-2011, 04:47 PM -
Central heating - boiler valve replacement?
By Jamie123 in forum Plumbing ForumReplies: 5Last Post: 12-12-2010, 10:05 PM -
Replacement of Central Heating
By manorpurl in forum Central Heating ForumReplies: 2Last Post: 24-02-2010, 07:30 PM -
Central Heating Replacement in a 4 bed house
By manorpurl in forum Central Heating ForumReplies: 11Last Post: 26-01-2010, 07:43 PM -
Central Heating Pump
By help in forum Plumbing ForumReplies: 8Last Post: 26-03-2009, 03:26 PM
Unvented direct cylinders in 5...
12 Minutes Ago in Plumbing Forum
