Results 1 to 12 of 15
Plumbing & Plumbers Forum - Intermittent firing on Trianco Eurostar Boiler
Discuss Intermittent firing on Trianco Eurostar Boiler at UK Plumbers Forums; Hello I wonder if anyone could throw any light on a very tiresome problem. We have the above oil fired boiler. The engineer has been out and seemingly tried everything. ...
    Default Intermittent firing on Trianco Eurostar Boiler
    Hello
    I wonder if anyone could throw any light on a very tiresome problem. We have the above oil fired boiler. The engineer has been out and seemingly tried everything. He has serviced it, replaced the injector leads, altered the power thingy lol to the burner, and goodness knows what else.
    After altering the injector, it did fire up on it's own for a day, and now is back to having to manually press the reset button. I am sure he is as frustrated as we are, but now the cold weather is coming I really don't want to have to keep doing this.
    Another thing, today, when I pressed the reset button it looked like a little flame came out of the box surrounding the button, which is worrying....
    Any ideas???
    Thank you for your time.
    Jan 2011
    Newton Abbot
    893
    Default Re: Intermittent firing on Trianco Eurostar Boiler
    It is always difficult to diagnose a fault without actually being there. We need to know exactly what happens when the boiler locks out, does it happen when you are there or does it happen overnight etc. The engineer has obviously checked certain things but things to check would be partially blocked oil filter, worn drive dog, faulty solenoid, faulty transformer whether the pump pressure is steady etc. A trained competent engineer should be able to at least recognise where the fault may lie. If it is an intermittent fault then that can be a different story.If the engineer cant sort it I doubt whether you will be able to, You will have to get the engineer to give you some idea of what he is going to do or you will have to change the engineer.
    Trianco eurostars go through a lot of photocells and solenoids.
  3. The Following 2 Users Say Thank You to kimbo For This Useful Post:
    Thank you for your reply Kimbo, I was not considering tackling anything myself but rather trying to see if there was just something that could help a little. The Engineer is a very nice man just scratching his head now! I will mention the parts that you have mentioned and see if he has a lightbulb moment! In answer to your question of timing of this, it is not on the timer, I just leave the hot water on constant and use the thermostat to put the heating on as and when. When I come down in the mornings it is always out, and have to reset it, sometimes takes more than one go. Sometimes after showers baths etc it will fire up and sometimes it doesn't. So very random really.
    Thank you very much.
    N.Ireland, United Kingdom
    6,994
    As Kimbo has said, it could be anything. Assuming everything obvious is ok, then I would add, - motor or motor capacitor. If it fails to start in morning it may have locked out previous night. If it is cold start problem, then flame not igniting as electrodes or combustion wrong. On first going to the boiler I would first - check basics like oil filters & mechanical parts like oil pump , motor and drives. If all ok then solenoid, control box, motor capacitor and photocell, perhaps in that order. Easy to change. Transformer is usually fine if good spark. Should be noted that solenoids if faulty, tend to not work at all or else only work in periods which can vary up to about 1 hr if boiler not cutting on & off too much, ie only heating hot water.
    dontknowitall's Avatar
    Apr 2008
    Herefordshire
    6,122
    What's the state of the fire valve? I've had one recently locking out after about 10 minutes of running, reset then lock out after 30 seconds. Left for quarter of an hour then boiler ran again for around 2 minutes.
    Many fire valves suffered last winter and with recent rain, if water has got in it might explain why it was working during the (dry) summer but not now.
    Jan 2011
    Newton Abbot
    893
    Cold starts is sometimes indicative of the capacitor as there is more drag on the motor when cold. Also ther could also be air in the system and overnight it wont allow the boiler to start it might take a number of attempts to get rid of a small amount of air.. If the motor turns every time you reset the lockout button before it starts it does not sound like anything seized. Methodical approach is the best and check everything through thoroughly starting from the tank with the filters and joints etc
  8. The Following User Says Thank You to kimbo For This Useful Post:
  9. #7
    6,994
    I agree. Capacitors are often overlooked. If you turn boiler on several times, you sometimes find that motor will suddenly fail to turn, with only a hum noise. Then probably oil pump/ motor has stopped on a more tighter spot which shows the capacitor weak. If any motor has a split second hum every time it goes to start, same applies. Faulty, tight oil pumps & motors ruin capacitors, so pays to change them.
  10. #8
    hiya i dont tink there is anything wrong wit your boiler/burner,i think the problem is your boiler is not being called on when you want it from the motorised valves,it would be worth checking the motorised valves,they are probably in your hot press and it is very common for them to jam and need replacing.you should get a plumber he will figure it out quite quickly!!
  11. #9
    6,994
    Quote Originally Posted by gpm86 View Post
    No, def has to be with the burner on the boiler not firing when it gets power, because owner stated it is going to lock out -( on control box which is at burner only)
  12. #10
    Jan 2008
    North Yorkshire
    4,777
    What happens before it goes to lockout? Does the motor turn OK? Does it ignite?
    Do the electrodes arc correctly when they are supposed to?
    If you say you got a flash from the control box it may be bust now. This is sometimes caused by a failing ignition transformer
  13. The Following User Says Thank You to WHPES For This Useful Post:
  14. #11
    6,994
    Quote Originally Posted by WHPES View Post
    I was assuming the " flash" they mentioned was the normal spark you see through the clear satronic control box that may be on the burner. Eurotraders had Sterling burners ( & other types) which often use Satronic boxes. That's the trouble, not enough info.
  15. #12
    Jan 2008
    North Yorkshire
    4,777
    I had a faulty transformer last year actually melted a control box.
  1. Trianco Eurostar Oil Boiler Conundrum
    By WHPES in forum Oil and Solid Fuel Forum
    Last Post: 01-12-2014, 05:21 PM
  2. Trianco Eurostar problem
    By Bunker in forum Oil and Solid Fuel Forum
    Last Post: 19-05-2013, 11:46 PM
  3. Potterton boiler intermittent firing
    By Willenium in forum Plumbing Forum
    Last Post: 28-02-2013, 08:15 PM
  4. Replacing Trianco Eurostar 110 - any help appreciated please
    By rossm in forum Oil and Solid Fuel Forum
    Last Post: 21-04-2012, 08:42 AM
  5. Trianco Eurostar Oil Boiler Conundrum
    By WHPES in forum Central Heating Forum
    Last Post: 18-12-2011, 11:14 AM
  6. Boiler not firing up - intermittent problem
    By Battenburg in forum Central Heating Forum
    Last Post: 17-01-2011, 09:42 PM
  7. Trianco TRG 45 Eurostar Solid Fuel.
    By Jazz Head in forum Central Heating Forum
    Last Post: 14-11-2010, 12:30 PM
  8. Trianco Eurostar 65 will not flame
    By etaf in forum Central Heating Forum
    Last Post: 24-12-2008, 05:39 PM
  9. 'Creative plumbing' delivers beer
    By uug197h in forum General Off-Topic Chat
    Last Post: 09-12-2008, 09:43 PM
trianco eurostar
trianco oil boiler problems
trianco eurostar oil boiler problems
trianco eurostar 150
trianco boiler not firing up
