Results 1 to 1 of 1
Plumbing & Plumbers Forum - worcester greenstar 42cdi problems
Discuss worcester greenstar 42cdi problems in the Central Heating Forum at Plumbers Forums; got call to one of theses today, problem is the temp on the boiler when hot water is on the display gos to 61 then starts counting down and runs ...-
24-10-2011 #1Plumbers Arms member
- Dec 2010
- redcar & cleveland
- 431
- 8
- Thanked 38 Times in 37 Posts
got call to one of theses today, problem is the temp on the boiler when hot water is on the display gos to 61 then starts counting down and runs cold. the flow pipe is getting hot, so took motor of and cleaned the paddle and all was fine temp going right up loads of hot water but flow pipe is just as hot now could the dv be at fault or is plate blocked up
worcester 42cdi
By tackleburger in forum Central Heating ForumReplies: 3Last Post: 25-06-2011, 11:34 PM -
worcester bosch 42cdi
By krav965 in forum Central Heating ForumReplies: 8Last Post: 11-03-2011, 08:26 PM -
Problems with water inside 4 year old Worcester Greenstar 25si
By csav in forum Plumbing ForumReplies: 0Last Post: 16-02-2011, 01:05 PM -
Worcester Greenstar 42CDi possible programmer fault
By tennooge in forum Central Heating ForumReplies: 0Last Post: 05-12-2010, 08:03 PM -
worcester bosch greenstar 24i problems
By meljb in forum Central Heating ForumReplies: 2Last Post: 18-02-2010, 12:11 PM
what is it ?
1 Hour Ago in General Off-Topic Chat
