Plumbing & Plumbers Forum - Rad Sizing - Condensing Combi - Help
Discuss Rad Sizing - Condensing Combi - Help in the Central Heating Forum at Plumbers Forums; I wonder if someone could advise best practice regarding rad sizing... House is Victorian semi - 5 beds - 3 reception - 1 bath - 10ft ceilings. Longest run to ...
    Sep 2011
    Default Rad Sizing - Condensing Combi - Help
    House is Victorian semi - 5 beds - 3 reception - 1 bath - 10ft ceilings. Longest run to rads is 25 metres for the upstairs front bedroom - the boiler is at the rear of the house.
    I have just finished calculating the heat loss for each room using Stelrad Stars - the total of which is in the order or 20kw. This was calculated at a minus 5°C outside temperature - this recalculates to around 18Kw at minus 3°C.
    The heat loss figures as yet do not include a 10% pipe loss / fast warm up calculation - or a BOE calculation. I'm not sure whether the quoted outputs from Stelrad are for BOE or TBOE etc. Will check with them. I wonder too what flow rate the outputs are based upon and how much that matters?
    Boiler is an Intergas 36/30 - radiators will be Stelrad Softline. Boiler will have an external compensating sensor.
    The boiler manufacturers data recommends a 20°C supply / return differential if possible - but don't state an ideal return temp. I'm going to assume / aim somewhere below 55°C to achieve better condensing.
    So - what should be my next steps?
    I can calculate each individual room Delta T as I have the correction table for the rads - which will enable me to more accurately size them.
    What flow / return temps should I use? 70/50 - 73/53 - 75/55 - any other combination? I see many installers struggle to get a 20°C differential - what factors affect this? Should i aim for a 15°C differential or less?
    What other matters should I take into account?
    Thanks!
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default
    Wow. I think you've really put too much effort in to this. But very good for what you have done
    If your worried about flow rates
    Never run more than 2 rads off a price of 15. And run 22 as far as you can
    I think youll be more than fine
  3. "nothing is impossible"
    7,210
    Default Re: Rad Sizing - Condensing Combi - Help
    Quote Originally Posted by SimonJohns View Post
    Don't think I put that much effort in when I was an apprentice at college!!!!
    leelister6's Avatar
    Sheffield
    652
    Just cube yer room in feet, times by 4, that will give ya BTU's then go 2 rad sizes up. Then go 4 a pint, watch Top Gear, gi your lass a slap an fall asleep on settee wi your kecks round your ankles. That'lle be £200 for the advice. I accept paypal
    Sep 2011
    I thought this was a forum full of pro's
    I like to do things to best practice - learned the hard way!
  1. Condensing Combi
    By Spanner2k7 in forum Central Heating Forum
    Last Post: 05-09-2011, 08:56 PM
  2. combi boiler for a combi condensing
    By ballandco in forum Gas Safe Register Forum - Public Forum
    Last Post: 13-05-2011, 05:15 PM
  3. Pressure problem in condensing combi
    By robbo32 in forum Plumbing Forum
    Last Post: 17-01-2011, 01:25 PM
  4. Condensing Combi losing pressure
    By Fusion in forum Central Heating Forum
    Last Post: 29-12-2009, 04:56 PM
  5. Combi Boiler Sizing/Flow Rates
    By woodbine in forum Plumbing Forum
    Last Post: 11-09-2009, 11:02 PM
marco combi settee
rad sizes for condensing combi
