Results 1 to 12 of 14
Plumbing & Plumbers Forum - Pumps on the return
Like Tree2Likes
Pumps on the return
Discuss Pumps on the return at UK Plumbers Forums; Can anyone tell me why it was prefered to put circulating pumps on the return side of heating systems a few years back , its just that i have circulating ...
    Jan 2009
    186
    Default Pumps on the return
    Can anyone tell me why it was prefered to put circulating pumps on the return side of heating systems a few years back , its just that i have circulating problems on a largeish system and i am thinking that the pump has to work so much harder , or does it because if a pump is at a neutral point wont it work well either way ? thanks for any input .
    stevetheplumber's Avatar
    east london
    10,613
    Default Re: Pumps on the return
    pump can go any way realy its the relationship between pump, cold feed and vent thats important to prevent pump over or air being sucked in years ago when we always put the cold feed and vent to seperate tappings on the boiler pump was often on the flow but i think the lower return temps prolonged pump life
    even now im comming across smc pumps that have been in 40 plus years often wonder where the worlds oldest working central heating pump is
    Jan 2009
    186
    Thanks steve , cleared slightly muddy water , as you say there must be a pump out there as old as the hills, never thought of cooler return temps prolonging life but obvious really .
    migoplumber's Avatar
    blackpool
    2,138
    steve's right about the prolonged pump life. with todays better component manufacture, its not so important, the news pumps are built better
    also with our newer systems generally there are 2 c/h circuits one for constant temperature, one for variable temperature. pumps need to be installed on flow for this type to system to work effieciently
    shaun
    Jan 2009
    186
    Shaun, out of interest what is a constant temp circut , is it if say you set room stat to 20 degrees centigrade thats where it stays where as say a compensator goes with temp change outside , cheers
    blackpool
    2,138
    constant temp circuits is the boiler flow temp circuit, typically for radiators.
    variable temp cct is where a lower temperature than boiler flow is needed for example
    boiler set at 80 degreees, constant temp to hot water cylinder, and radiators, (which in turn are self regulating (t.r.v.s and cylinder stat))
    underfloor heating on variable temperature maybe 55 (controlled by a 3 way motorized valve that sends boiler flow directly back to the return when the water in the cct has reached the temperature set point) or maybe in a schooll where they only want 40 degrees in the rad.
    the boiler is designed to operate at max effiecency at a certain temp, be it 60 or 90
    using this vt cct you can obtain a desired temperatue in a designed zone, at 100% boiler effiecency
    not very good at explaining stuff, but i hope you get the jist.
    shaun
    Jan 2009
    186
    Thanks shaun, yes i do get the jist , its my language
    Feb 2012
    17
    I realise that this thread is, on the whole, some 4 years old but I have a question :- I have a piping schematic for a Rayburn solid fuel CH Cooker. It shows the pump on the return but before the injector tee. Can the pump be fitted on the flow side instead? I don't imagine it would affect the injector tee as the flow into the tee would still be at pressure. Additionally, although the diagram shows the ''venturi suction'' inlet to the tee from the cylinder return + the feed & expansion tank is there any reason why that inlet could not be just from the F & E tank with the cylinder circuit being treated as another radiator.
    AWheating's Avatar
    WestMidlands
    9,638
    with standard solid fuel installs the cylinder cant be treated as another radiator, it needs to be gravity and open to stop major safety issues. Best to employ a hetas qualified engineer to install it for you.
    He who dares Wins, unless he dares to try and breath under water.
    tamz's Avatar
    Scotland
    13,954
    Follow the Rayburn instructions. It will save a lot of explaining as why it should be like that and get someone who is qualified and knows what they are doing to fit it.
    AWheating likes this.
    Forum Thug
    croppie's Avatar
    23,822
    Definitely not a diy job. You may not believe it but the majority of your plumbing will try to kill you if you give it half a chance.
    As AW and Tamz have rightly stated, get a HETAS qualified guy (or gal, we're all for equality!) in.
    Croppie
    (By the way, I'm commercial!)
  1. Hot return
    By Mgrant in forum Plumbing Forum
    Last Post: 05-09-2013, 09:23 PM
  2. two pumps
    By Iain Hunter in forum Central Heating Forum
    Last Post: 01-03-2013, 09:22 AM
  3. Pumps
    By HawkWhiteFinger in forum Central Heating Forum
    Last Post: 30-04-2012, 11:26 AM
  4. DAB Pumps
    By dancinplumba in forum For Sale & Wanted
    Last Post: 08-02-2012, 09:24 PM
  5. Pumps
    By poorman in forum Central Heating Forum
    Last Post: 31-08-2011, 07:47 AM
  6. condense pumps!!
    By kisa in forum Central Heating Forum
    Last Post: 05-06-2011, 06:12 PM
  7. Pumps
    By PlumbingSucks in forum Central Heating Forum
    Last Post: 11-11-2010, 11:18 PM
  8. Pumps pumps pumps
    By Plumbstar Tom in forum Plumbing Forum
    Last Post: 13-03-2010, 10:39 AM
  9. on job training
    By amanda in forum Plumbing Courses
    Last Post: 14-10-2007, 11:21 AM
circulating pump on flow or return
central heating pump on flow or return
does central heating pump go on flow or return
boiler pump on flow or return
heating pump flow or return
