Plumbing & Plumbers Forum - Heat Loss Calcs - Air Changes
Discuss Heat Loss Calcs - Air Changes in the Central Heating Forum at Plumbers Forums; Hi again everyone Just about finished all my heat loss calcs with Stelrad Stars. I just wondered about the ventilation / air changes. These significantly affect the heat requirements. Currently ...-
18-10-2011 #1New to Plumbing Forum
- Sep 2011
- 8
Hi again everyone
Currently they are set as the following changes per hour :
- Living Room - 3
- Drawing Room - 3
- Dining Room - 2
- Hall - 2
- Kitchen - 3
- Utility Room - 2
- Landing - 2
- Bathroom - 3
- Bedrooms - 1.5
All the upper floor rooms have double glazed windows. The ground floor rooms are mostly single - weatherstripped - soon to be double glazed. Ground floors are suspended timber. Living & Drawing rooms have open fires with requisite chimneys.
Are these air changes per hour about right?
18-10-2011 #2UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 5,789
- 124
Re: Heat Loss Calcs - Air Changes
without checking my notes i think i normally allow 3 for rooms with extract fan and 1.5-2 for other rooms. Its been about 8 months since i have done long hand calculations tho.
btw im commercial, NOT.
18-10-2011 #3fuzzyGuest
18-10-2011 #4UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
- Thanked 676 Times in 610 Posts
Slight tongue in cheek remark but don't these figures get thrown out of the window when the windows are open? And if it's blowing a gale ...
18-10-2011 #5New to Plumbing Forum
- Sep 2011
- 8
Would two changes suffice for the rooms with open fires (chinmeys) and suspended timber floors with plenty of underfloor ventilation?
The house by the way is a victorian semi with 10ft ceilings - and a bit draughty here & there - though I'm attending to that as best I can with weatherstripping etc.
18-10-2011 #6UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Lol. Just to add. New builds should have an air change of 0.5 per hour !!!!
"nothing is impossible"
21-10-2011 #7fuzzyGuest
1.5 should be fine, the size of the room is part of the calc in a different area so no need to compensate here as well
Heat Loss Calcs - Stairwell
By machineage in forum Central Heating ForumReplies: 5Last Post: 01-10-2011, 04:37 PM -
Heat loss calc
By eaton in forum Renewable EnergyReplies: 2Last Post: 22-09-2011, 07:48 PM -
Check These Calcs
By Choclate gold in forum Plumbing ForumReplies: 16Last Post: 02-05-2011, 08:45 AM -
Baxi Megaflo Boiler - 'crackling' noise & heat loss
By hastings in forum Central Heating ForumReplies: 2Last Post: 04-08-2010, 06:32 PM -
Heat loss calculations
By PH951 in forum Central Heating ForumReplies: 6Last Post: 23-08-2008, 10:08 AM
Combi boiler in bedroom
2 Minutes Ago in Central Heating Forum
