Results 1 to 8 of 8
Plumbing & Plumbers Forum - Firebird oil boiler, black smoke problem
Discuss Firebird oil boiler, black smoke problem in the Central Heating Forum at Plumbers Forums; Hello guys, new member here. I have a firebird oil boiler. It has worked fine up until a few days ago. There was black smoke coming out the flue and ...
    Default Firebird oil boiler, black smoke problem
    Hello guys, new member here. I have a firebird oil boiler. It has worked fine up until a few days ago. There was black smoke coming out the flue and there is a build up of soot inside the vent. Can I clean this myself ? Will I need a specialist to sort it. I have turned the system off now as I am using an immersion heater for now, but obviously we have no heating and its gonna get cold in the next few weeks.
    Thanks for any help/info much appreciated
    Rob
    BOD
    BOD is offline
    BOD's Avatar
    Nov 2009
    10,552
    Default Re: Firebird oil boiler, black smoke problem
    best to get a pro in and check it fully fella
    Jan 2011
    Newton Abbot
    652
    Yes get an OFTEC guy in, the boiler will ned to be cleaned and nozzle changed, pump pressure checked also flue gas readings may need to be adjusted etc. You will not be able to do these things on your own. You may want to clean it out yourself and you may be lucky but something has caused it to go sooty and only an experienced engineer will be able to find what it was.
    Basically soot is unburnt fuel.
    Banned
    Aug 2011
    Telford shrops
    defo a oftec guy needed it could be a faulty wrong size nozzel wrong pump pressure sooted up baffles etc etc
    Jan 2008
    North Yorkshire
    4,150
    you can locate your nearest technician at Oil Firing Technical Association - registered professionals for the the oil heating and cooking industry - OFTEC, Kesgrave, Ipswich and go to the find a technician tab
    Is it a vertical flue? If so, may need a chimney sweep too.
    Evidence of soot means carbon monoxide being produced so be careful.
    Okay guys thanks for your replies. I will get someone in then. I wanted to do it myself to save on the pennies but safety first....so thanks again guys !!!
    BOD
    BOD is offline
    BOD's Avatar
    Nov 2009
    10,552
    if only there were more like you robster that werent willing to risk there lifes and others for a sake of a few quid. where are you located
    Plumbers Arms member Jimmeh's Avatar
    Jun 2011
    Truro, Cornwall
    58
    yup go to Oftec's website and find one of us Oftec Engineers should be a simple fix as previously mentioned, however he will need to look into the causes of the soot build up, which as mentioned above is probably due to incorrect O2 amount and maybe an incorrect nozzle fitted. The oftec engineer may well want the original boiler manual if available too.
  1. Firebird oil boiler non starter
    By wolbut in forum Central Heating Forum
    Last Post: 26-09-2011, 08:49 PM
  2. firebird enviromax slimline condensing combi 20kw......problem
    By cameron66 in forum Central Heating Forum
    Last Post: 28-02-2011, 10:06 PM
  3. Firebird oil boiler
    By doug in forum Central Heating Forum
    Last Post: 23-12-2010, 12:28 AM
  4. warmflow riello rdb3 burner kicking out black smoke
    By mojorisin in forum Plumbing Forum
    Last Post: 15-12-2010, 10:25 PM
  5. Firebird C20 70K Combi Boiler no DHW
    By Bohica41 in forum Central Heating Forum
    Last Post: 11-04-2010, 06:15 PM
firebird oil boiler problems
firebird boiler black smoke
firebird oil burner problems
oil boiler smoking
black smoke from oil burner
black smoke from oil boiler
oil boiler black smoke
