Results 1 to 6 of 6
Plumbing & Plumbers Forum - Glow worm ultracom 18hxi-occasional 100 degrees/boil
Discuss Glow worm ultracom 18hxi-occasional 100 degrees/boil in the Central Heating Forum at Plumbers Forums; Hi everyone Thought I'd run this problem past you guys in case someone has come across it before. Basically my boiler is heating my tank up fine, but occasionally when ...
    Default Glow worm ultracom 18hxi-occasional 100 degrees/boil
    Hi everyone
    Thought I'd run this problem past you guys in case someone has come across it before. Basically my boiler is heating my tank up fine, but occasionally when the stat is not calling for heat the boiler fires up. Within a few seconds the temperature races up to around the 100 degree mark and then switches off ( and making a bit more noise whilst doing so). The boiler is not showing a fault code. I imagine this is not doing the boiler any good. I guess that an inevitable call to Glow worm is in order.
    Thanks for reading
    Dave
    Nov 2009
    421
    Default Re: Glow worm ultracom 18hxi-occasional 100 degrees/boil
    diverter is stuck or sticking. Think 100degrees may be a bit beyond what I've ever witnessed, Give BG a ring, they'll be cheaper
    armourer's Avatar
    Jun 2011
    Midlands
    537
    Or get a local GSR engineer in they will be cheaper than Glowworm or BG.
    Nov 2009
    421
    Quote Originally Posted by armourer View Post
    You say that but where there's expensive parts to fit or heat exchangers etc.. but a hundred and odd quid for a first fix (lol!) wouldn't be a bad deal
    Dec 2011
    glowworm 18hxi f4 Fault - any ideas?
    diamondgas's Avatar
    Newcastle Upon tyne
    6,050
    Quote Originally Posted by jayh1969 View Post
    F4 is ignition lockout jayh1969 ... Lots of possible causes on that one .... Only thing you can do is make sure you haven't ran out of gas or accidently turned off the main control valve next to the meter
  1. Glow Worm Ultracom CXi ..... Which Stat or Programmer???
    By jayHH in forum Central Heating Forum
    Last Post: 30-01-2011, 12:20 AM
  2. Glow Worm 18Hxi
    By smillsey in forum Gas Safe Register Forum - Public Forum
    Last Post: 28-01-2011, 07:17 PM
  3. New Glow Worm Ultracom 18sxi wont switch off !!!
    By quattro64 in forum Central Heating Forum
    Last Post: 02-01-2011, 10:59 AM
  4. Glow worm ultracom
    By sparky in forum Central Heating Forum
    Last Post: 11-03-2010, 08:20 PM
  5. Glow Worm ultracom 38cxi heating
    By shedman in forum Central Heating Forum
    Last Post: 13-12-2009, 09:20 AM
glow worm 18hxi f4 fault
glow worm ultracom 18hxi problems
glow worm 18hxi fault f4
what temperature should glow worm 18hxi run at
glow worm 18hxi f4
ultracom 18hxi F4 fault code
