Plumbing & Plumbers Forum - Copper Cylinder Question?
Discuss Copper Cylinder Question? in the Central Heating Forum at Plumbers Forums; Afternoon gents, just a quick question... Is it possible to convert a copper cylinder used for an electric immersion heater, to insert a copper coil so it can be used ...-
02-10-2011 #1New to Plumbing Forum
- Jan 2011
- 20
- 20
Is it possible to convert a copper cylinder used for an electric immersion heater, to insert a copper coil so it can be used for gas central heating?
If the answer is yes, is it done often and what are the arguements aginst doing this?
Thanks in advance..
02-10-2011 #2
Re: Copper Cylinder Question?
This was common during the 70s copper shortage and was done by using salamander or side-winder tubes. Side-winder required two holes to be drilled and the coil was inserted in the side of the cylinder. The salamander was inserted into the immersion boss in the top. Both worked ok, but more modern coils have a greater heat exchange for efficiency.
Have you checked out the price of stainless cylinders for open indirect systems? These are cheaper than copper cylinders now and more suitable in soft water areas.
The Following User Says Thank You to Clanger For This Useful Post:
biggjedd (02-10-2011)
02-10-2011 #3Plumbers Arms member
- Apr 2010
- 1,399
- 61
- Thanked 167 Times in 157 Posts
Inefficient, prone to leaks and a waste of time and effort!
Scrap the cylinder and put the cost towards a new cylinder.
The Following User Says Thank You to GrahamM For This Useful Post:
02-10-2011 #4New to Plumbing Forum
- Jan 2011
- 20
- 20
Gents, thanks for your replies. This was a question for my own information.
I recently posted a thread titled "pressure problems" and eventually ascertained it was the coil which was leaking.
My system is only 6 years old and I paid kevin the cowboy and his pal to install a brand new system for me. Never haggled with his price and accepted he was going to do as promised. I remember walking into the room where the cylinder was and he had a huge coil of copper tube and when he saw me he had the look of a startled rabbit in headlights!! Of course I didn't know what he was doing or what the coil was for!! He left me with 23 leaks, most of which I had to repair myself!!!
I changed the cylinder myself as well a few days ago and there's a hell of a difference to the water and heating. At this time I realised this was the old immersion cylinder I removed, hence the reason for submitting this post. It's assholes like kevin who give you guys a bad name and lose custom because us laymen end up doing the work ourselves!! For the sakes of saving a few quid, the idiot's caused me no end of problems. I paid him £4k for the job and the cylinder I just bought was £130. Surely easier just to supply a new cylinder as promised, for that little amount?!!
Anyway, thanks to everyone who replied with advice.
02-10-2011 #5UK Plumbersforums Trusted Advisor.
- Jan 2008
- North Yorkshire
- 4,150
I was told that at one time many years ago (pre 50s I guess) you had to fit coils to cylinders in this way as they didnt come ready assembled. Never seen such a thing for sale, but I have seen very old cylinders with nuts threaded onto the oultets appearing to clamp up agianst the cylinder wall.
The Following User Says Thank You to WHPES For This Useful Post:
How to remove a heating element from a copper cylinder
By Michael29068 in forum Plumbing ForumReplies: 20Last Post: 31-05-2011, 01:07 AM -
Copper cylinder insulation
By Plamber in forum Plumbing ForumReplies: 19Last Post: 02-04-2011, 11:56 PM -
Best way to cut hole in copper cylinder?
By LeakyNick in forum Plumbing ForumReplies: 6Last Post: 05-02-2011, 09:38 PM -
square copper h/w 'cylinder'
By REDSAW in forum Central Heating ForumReplies: 7Last Post: 22-10-2010, 07:59 AM -
copper cylinder removal
By princeknight in forum Plumbing ForumReplies: 6Last Post: 30-11-2009, 09:21 PM
heat pumps course
4 Minutes Ago in Renewable Energy
