Results 1 to 9 of 9
Plumbing & Plumbers Forum - No hot water the boiler fires up to heat the water
Discuss No hot water the boiler fires up to heat the water in the Central Heating Forum at Plumbers Forums; Hi, If anyone can give me a bit of technical advice why my halstead Ace boiler wont give out hot water. When I run the tap it fires up to ...
    Sep 2011
    Default No hot water the boiler fires up to heat the water
    Hi, If anyone can give me a bit of technical advice why my halstead Ace boiler wont give out hot water. When I run the tap it fires up to heat the heat exchanger. I changed the diverter vale diaghragm a few months ago.
    Plumbers Arms member jase158's Avatar
    Sep 2010
    2,067
    Default Re: No hot water the boiler fires up to heat the water
    is it combi boiler?
    are you gas safe registered?
    did it work after you changed diverter valve?
    Sep 2011
    Yes it is a a combi boiler
    No was corgi a few years ago
    Yes worked fine
    It stopped working after I changed a washer just before the heat exchanger as it was leaking.
    AWheating's Avatar
    WestMidlands
    5,777
    blockage?
    btw im commercial,
    NOT.
    Sep 2011
    my understanding is there is two parts working to make hot water in a combi boiler. The first is a pump pumping water round in a circle from the heat exchanger to the secondary heat exchanger. The second is the cold water feed into the boiler passing through the secondary heat exchanger and out as the hot water.
    I Pressume the first part is blocked?
    When I put central heating on the the pipe from the heat exchanger to the secondary heat exchanger warms up
    armourer's Avatar
    Jun 2011
    Midlands
    537
    Is your central heating flow pipe getting hot when you turn on a hot tap?
    I am thinking the plate heat exchanger maybe blocked and it will bypass to the central heating. (assuming your diverter valve is working OK)?
    Sep 2011
    Is it best to drain the system down refill with a flush run for an hour drain again and hope for the best.
    or
    Drain down and take the secondary heat exchanger out and try and clean.
    armourer's Avatar
    Jun 2011
    Midlands
    537
    You will have to remove the secondary heat ex and flush it through with a hose pipe.
    Sep 2011
    Thanks I'll get on to it monday
  1. Replies: 2
    Last Post: 10-08-2011, 05:50 PM
  2. looking to heat water only
    By jstephens251 in forum Plumbing Forum
    Last Post: 03-06-2011, 08:19 PM
  3. Electric or Gas to heat water?
    By Help4me in forum Central Heating Forum
    Last Post: 24-03-2011, 03:08 PM
  4. Biasi 24S boiler taking ages to heat up water. Any ideas?
    By gemmcd in forum Central Heating Forum
    Last Post: 25-01-2009, 08:59 PM
  5. Replies: 6
    Last Post: 23-07-2008, 10:46 PM
boiler fires no hot water
boiler wont give hot water
ukplumbersforums.co.uk halstead boiler no hot water
halstead boiler wont give me hot water
boiler fires on no hot water
boiler wont fire up for hot water
boiler fires up but no heating or hot water
