Results 1 to 15 of 17
Plumbing & Plumbers Forum - worcester cbi 14/19 problem
Discuss worcester cbi 14/19 problem in the Central Heating Forum at Plumbers Forums; Lads....went the above boiler last week which wouldn't fire...followed mi's flow chart which led me to the aps...changed the aps and it worked inetermittantly, can hear aps clicking but no ...
    moogwai's Avatar
    Dec 2009
    birmingham
    1,135
    Default worcester cbi 14/19 problem
    Lads....went the above boiler last week which wouldn't fire...followed mi's flow chart which led me to the aps...changed the aps and it worked inetermittantly, can hear aps clicking but no ignition. I took out the fan and gave it a clean made sure venturies were clean...put it back in and it worked so i left. Had a call to back today to find it's still working intermittantly and when it does fire the ignition is slightly explosive.....could this be an ignition problem? if so should i be looking at replacing the pcb?
    any help would be appreciated. pm me if you like.
    redcar & cleveland
    431
    Default Re: worcester cbi 14/19 problem
    check gas valve for let by,,, also spark gap
    moogwai's Avatar
    Dec 2009
    birmingham
    1,135
    just got back from it again....worked first time when i called for heat....worked for a while up to temperature...cut out and never came back on. So i took cover off combsution chamber checked electrodes went through start up process with gas off...spark was present on around 10 times of asking. Cleaned electrodes checked the gap...put it all back together....worked fine so i left.
    Just had a phone call....not working again!!! aarrrggghhhh!!!! this is really doing my head in!!
    quality's Avatar
    Sep 2009
    South Yorkshire
    2,436
    I know you said you checked the fan but they are notorious for running slow when hot
    Maybe drink some free tea while it reachs temp next visit
  5. The Following User Says Thank You to quality For This Useful Post:
    moogwai (28-09-2011)
    moogwai's Avatar
    Dec 2009
    birmingham
    1,135
    Quote Originally Posted by quality View Post
    do they?? i'm at my wits end...how can i check if it runs slow when hot?? i don't think i could tell by eye. if this is a common prob then i'm just gonna renew it.
    quality's Avatar
    Sep 2009
    South Yorkshire
    2,436
    Use a multimeter to ensure the aps is satisfied
    redcar & cleveland
    431
    have you check flame sensing is in the correct position ive had one what was moving ones heated up and shut the boiler down
    moogwai's Avatar
    Dec 2009
    birmingham
    1,135
    thing thats getting me is that the fan still runs and runs (don't go into lock out) and even when the boiler has cooled it wont re-ignite itself unless i fiddle around with it!.....bloody bleedin thing....will have to spend an hour there with worcester tech on the phone.
    redcar & cleveland
    431
    nightmare let us no the outcome moogwai
    quality's Avatar
    Sep 2009
    South Yorkshire
    2,436
    Yes they do your box in jobs like these but at least you get a free lesson from them
    Aug 2010
    belfast
    166
    possible gas valve problem have you checked the resistance on the coils? worcester tech will tell you what it should be... also check your thermister if its not coming back on after it gets to temp good luck mate keep us posted
  13. #12
    moogwai's Avatar
    Dec 2009
    birmingham
    1,135
    going back monday to see what worcester say when i'm in front of the thing!!! will let you all know.
  14. #13
    58
    Have you checked for a flue restrictor plate? From memory these boilers had a restrictor that had to be fitted for a certain length of flue? Just a thought.
    Raymondo
  15. #14
    moogwai's Avatar
    Dec 2009
    birmingham
    1,135
    Quote Originally Posted by raymondo68 View Post
    Raymondo
    i havn't checked to be honest....all worked up until a couple of weeks ago and the flue goes straight out of the wall so i don't i don't think any thing is wrong regarding the flue.
  16. #15
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default
    There is also a ot stat that is self resetting. Maybe that is failing early
    Check continuity when hot
    "nothing is impossible"
  1. Worcester 24i problem
    By Jamie Walker in forum Central Heating Forum
    Last Post: 17-09-2011, 01:05 PM
  2. Worcester 28Si II Problem
    By John The Rad in forum Central Heating Forum
    Last Post: 17-01-2011, 12:37 AM
  3. problem with 28i worcester HE
    By wnjswozo in forum Central Heating Forum
    Last Post: 06-04-2010, 09:50 PM
  4. Worcester 240 PROBLEM!!!
    By Ch3nKo in forum Central Heating Forum
    Last Post: 02-12-2009, 09:28 PM
  5. Worcester 24i problem(20-04-09)
    By Goodeluck11 in forum Central Heating Forum
    Last Post: 22-04-2009, 08:56 PM
worcester 1924 cbi constantly locking out
worcester 1419 cbi lockout
worcester 1924 cb ignition explosive
problem with explosive ignition on worcester1419cbi boiler
worcester 19 24 cbi boiler
24cbi explosive ingition
worcester 1419 cbi cutting out
