Plumbing & Plumbers Forum - Ravenheat Ls100 white star problem.
Discuss Ravenheat Ls100 white star problem. in the Central Heating Forum at Plumbers Forums; Hi all Having a difficult time identifing a fault on a ravenheat (thats two in a month what have done wrong). Boiler will not light goes striaght to lock out. ...
    Sep 2011
    15
    Default Ravenheat Ls100 white star problem.
    Hi all
    Having a difficult time identifing a fault on a ravenheat (thats two in a month what have done wrong). Boiler will not light goes striaght to lock out. fan runs, pump runs but not start spark process. Ive got 230v at fan. Just after a bit of advice as dont want to put parts on a boiler which might not be needed.
    Jim
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default
    Check your aps for closure
    If you got that check your getting voltage to your gas valve. If your gas valve is getting voltage must be a failed spark generator
    Sometimes this can be linked to an overtemp situation too.
  3. "nothing is impossible"
    Sep 2011
    15
    Default Re: Ravenheat Ls100 white star problem.
    Thanks Simon
    I got voltage to gas valve. When i gentle blow down air pressure tube on ch mode the boiler will light and stay on. I've checked case seals with tapered match. I hate these boilers they just thrown together. Could it be the ignition control board. i spoke to ravenheat they reckon it be the thermisters.
    Jim
    Jul 2011
    Swansea
    Not familiar with this boiler, but from what you say, check flue venturi if clear then aps faulty.
    Top Plumbing Forum Contributor arran197's Avatar
    Aug 2011
    Wolverhampton
    697
    Ravenheats are unfortunately an absolute bag of poo. British engineering at it's worst tbh. Could be the thermister as I know on the CSI the boiler will do everything apart from open the gas valve and spark.
  1. Ravenheat combi RSF84ET no hot water problem
    By Marco in forum Central Heating Forum
    Last Post: 27-04-2011, 08:44 AM
  2. Ravenheat little star
    By joeshey in forum Central Heating Forum
    Last Post: 01-04-2011, 08:07 PM
  3. All Star Plumbing Ltd.
    By allstarplumbing in forum New Member Introductions
    Last Post: 30-08-2010, 08:22 PM
  4. Heatline Star 24
    By h17sym in forum Central Heating Forum
    Last Post: 08-02-2010, 11:15 PM
ravenheat ls100t problems
ravenheat ls 100
ravenheat white star
ravenheat white star boiler problems
ravenheat white star ls100t
ravenheat ls100t no hot water
ravenheat whitestar
