Results 1 to 2 of 2
Plumbing & Plumbers Forum - Worcester 24cdi not filling
Discuss Worcester 24cdi not filling in the Central Heating Forum at Plumbers Forums; I have today been to a repair on a 24cdi but cannot re pressurise the system,I have the correct key in the correct position, is there any other filters other ...-
24-09-2011 #1New to Plumbing Forum
- Aug 2011
- 10
- 10
I have today been to a repair on a 24cdi but cannot re pressurise the system,I have the correct key in the correct position, is there any other filters other than on water inlet to diverter?
24-09-2011 #2Plumbers Arms member
- May 2010
- 595
- 14
- Thanked 32 Times in 32 Posts
Re: Worcester 24cdi not filling
I thought it was just the water inlet filter on that little fill loop. Im guessing you opened the little grey tap under the boiler to let the water in, maybe its seized shut?
DId you try opening the water inlet without the key in place? if that works maybe its the built in non-return valve jammed?
Worcester 24cdi dripping
By tonyacktar in forum Central Heating ForumReplies: 1Last Post: 21-08-2011, 05:42 PM -
worcester 24cdi rsf
By warehouseman in forum Central Heating ForumReplies: 14Last Post: 23-05-2011, 05:32 PM -
Worcester 24CDi RSF
By mlhifi in forum Plumbing ForumReplies: 0Last Post: 17-04-2011, 01:55 PM -
Worcester 24CDI Fault.
By gregsi1 in forum Plumbing ForumReplies: 8Last Post: 18-08-2010, 07:43 PM
Relief valve for Unvented Indirect...
4 Hours Ago in Plumbing Forum
